hi, i am trying to takeover a 2012 dc (2008r2 ad) and always failing that s4 does not start in the middle
any idea what this means? cant find anything in the logs except that
File "/usr/lib/pymodules/python2.7/univention/s4connector/s4/main.py", line 279, in main
connect()
File "/usr/lib/pymodules/python2.7/univention/s4connector/s4/main.py", line 158, in connect
mapping.s4_mapping,
AttributeError: 'module' object has no attribute 's4_mapping'
we ran ad connector before and i added the takeover modul extra
Okt 05 13:47:17 UCS named[31943]: Loading 'samba4.zone' using driver dlopen
Okt 05 13:47:17 UCS named[31943]: samba_dlz: started for DN DC=feuerwehr-goldbach,DC=local
Okt 05 13:47:17 UCS named[31943]: samba_dlz: starting configure
Okt 05 13:47:17 UCS named[31943]: samba_dlz: trying partition 'CN=MicrosoftDNS,DC=DomainDnsZones,DC=feuerwehr
Okt 05 13:47:17 UCS named[31943]: samba_dlz: configured writeable zone 'feuerwehr-goldbach.local'
Okt 05 13:47:17 UCS named[31943]: samba_dlz: configured writeable zone '17.168.192.in-addr.arpa'
Okt 05 13:47:17 UCS named[31943]: samba_dlz: trying partition 'CN=MicrosoftDNS,DC=ForestDnsZones,DC=feuerwehr
Okt 05 13:47:17 UCS named[31943]: samba_dlz b9_format: unhandled record type 65281
Okt 05 13:47:17 UCS named[31943]: zone _msdcs.feuerwehr-goldbach.local/NONE: could not find NS and/or SOA rec
Okt 05 13:47:17 UCS named[31943]: zone _msdcs.feuerwehr-goldbach.local/NONE: has 0 SOA records
Okt 05 13:47:17 UCS named[31943]: zone _msdcs.feuerwehr-goldbach.local/NONE: has no NS records
Okt 05 13:47:17 UCS named[31943]: samba_dlz: Failed to configure zone '_msdcs.feuerwehr-goldbach.local'
Okt 05 13:47:17 UCS named[31943]: loading configuration: bad zone
Okt 05 13:47:17 UCS named[31943]: exiting (due to fatal error)
Okt 05 13:47:17 UCS systemd[1]: bind9.service: Main process exited, code=exited, status=1/FAILURE
Okt 05 13:47:18 UCS samba4[31946]: rndc: connect failed: 127.0.0.1#953: connection refused
Join Scipts 96 to 98 do not finish after Takeover Module Installation
Fr 5. Okt 16:13:38 CEST 2018
2018-10-05 16:13:38.908224180+02:00 (in joinscript_init)
/usr/lib/univention-install/96univention-samba4.inst: Zeile 42: Warnung: command substitution: ignored null byte in input
05.10.18 16:13:39.595 DEBUG_INIT
UNIVENTION_DEBUG_BEGIN : uldap.__open host=UCS.feuerwehr-goldbach.local port=7389 base=dc=feuerwehr-goldbach,dc=local
UNIVENTION_DEBUG_END : uldap.__open host=UCS.feuerwehr-goldbach.local port=7389 base=dc=feuerwehr-goldbach,dc=local
ERROR: The domain is in AD Member Mode, cannot join as DC.
EXITCODE=1
RUNNING 97univention-s4-connector.inst
2018-10-05 16:13:39.680939865+02:00 (in joinscript_init)
/usr/lib/univention-install/97univention-s4-connector.inst: Zeile 42: Warnung: command substitution: ignored null byte in input
05.10.18 16:13:40.263 DEBUG_INIT
ERROR: The domain is in AD Member Mode.
Not updating connector/s4/autostart
Setting connector/s4/listener/disabled
Module: kopano-cfg
Restarting univention-directory-listener (via systemctl): univention-directory-listener.service.
EXITCODE=1
2018-10-05 16:13:46.515392096+02:00 (in joinscript_init)
/usr/lib/univention-install/98univention-samba4-dns.inst: Zeile 42: Warnung: command substitution: ignored null byte in input
Samba4 backend database not available yet, exiting joinscript 98univention-samba4-dns.
EXITCODE=1
RUNNING 98univention-samba4-saml-kerberos.inst
2018-10-05 16:13:47.455323674+02:00 (in joinscript_init)
/usr/lib/univention-install/98univention-samba4-saml-kerberos.inst: Zeile 41: Warnung: command substitution: ignored null byte in input
Waiting for user replication...
ERROR: User ucs-sso not found
EXITCODE=1
Fr 5. Okt 16:14:00 CEST 2018
i have tried about 20 takeovers
is there another way or any idea?
like making a second dc first and seizing roles manually?
I have already Kopano running
but i´ll try now with a second and see if kopano will continue working
perhaps kopano support will help move installation later
but i wonder why that behavior occurs
i did this 10x the same way
I don’t know why it hangs, but I’ve never had the AD Connection set up first before installing and running AD Takeover.
Of course it might totally be due to the data in the current AD domain. This error hints that this might be the case:
Line 42 is simply reading UCR variables, and it seems there’s at least once UCR variable that contains a null byte. In order to find out which UCR variable this is, run the following:
grep -Pan '\x00' /etc/univention/base.conf
Maybe that’ll give us a clue where and why things go wrong.
root@UCS:~# grep -Pan ‘\x00’ /etc/univention/base.conf
423:mail/relayhost: firewall.markt-goldbach.de
i can post that, its no secret, the mx:)
but variable seems to be ok
removed perhaps null one and retried
s4 connector does not start
Sat Oct 6 13:50:02 2018
— connect failed, failure was: —
File “/usr/lib/pymodules/python2.7/univention/s4connector/s4/main.py”, line 279, in main
connect()
File “/usr/lib/pymodules/python2.7/univention/s4connector/s4/main.py”, line 158, in connect
mapping.s4_mapping,
AttributeError: ‘module’ object has no attribute ‘s4_mapping’
i rerun the join scripts before takeover, did not work
currently it hangs repeating the last messages all 30 sec forever
Earlier you said that the join scripts didn’t run after the installation of AD Takeover. The output showed the error about the null bytes. Having removed the null bytes, did you really execute univention-run-join-scripts
afterwards?
ill retry, i just tried while s4 tried to restart
now only 98univention-samba4-saml-kerberos is undone and he still complains about ucs-sso user missing
and some strange dns messages
Okt 06 13:56:54 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:56:55 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:56:56 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:56:57 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:56:58 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:56:59 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:57:00 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:57:02 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:57:03 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:57:04 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
Okt 06 13:57:05 UCS samba4[8646]: rndc: connect failed: 127.0.0.1#953: connection refused
2018-10-06 13:58:09.509062716+02:00 (in joinscript_init)
Waiting for user replication…
I don’t think I can really help you at this point. Your installation seems to be quite messed up — for whatever reason. Even if we try to continue fixing one issue after the other, I’m reasonably sure that the whole AD Takeover process won’t be completed that way.
If you cannot get it to work, and if there isn’t enough help available here, you can still opt to buy support directly from Univention. They do have the most experience with that topic, after all.
thanks moritz.
i just killed a s4 process and now its continuing syncinc
if it will fail, i´ll rollback
so frustrating
i did like you told me with another installation
after sucessful takeover bind does not start
so i changed to ldap backend
