Hello!
I installed UCS following oxpedia.org/wiki/index.php?title … _Connector
All looks good and green in web interface but below, in logs, horror
I have this error in /var/log/unnivention/connector.log
3.08.2010 16:01:26,372 LDAP (ERROR ): Unknown Exception during sync_to_ucs
13.08.2010 16:01:26,372 LDAP (ERROR ): – for details see /var/log/univention/connector-tracebacks.log –
13.08.2010 16:01:26,373 LDAP (WARNING): sync to ucs was not successfull, save rejected
13.08.2010 16:01:26,373 LDAP (WARNING): object was: CN=John Doe,OU=Users School,DC=school,DC=zeus
13.08.2010 16:01:31,447 LDAP (WARNING): __set_values: no ldap_attribute defined in <univention.connector.attribute instance at 0x7fa7082aae60>, we unset the key lastname in the ucs-object
13.08.2010 16:01:31,448 LDAP (WARNING): __set_values: The attributes for lastname have not been removed as it represents a mandatory attribute
13.08.2010 16:01:31,471 LDAP (WARNING): __set_values: no ldap_attribute defined in <univention.connector.attribute instance at 0x7fa7082aafc8>, we unset the key city in the ucs-object
13.08.2010 16:01:31,520 LDAP (WARNING): __set_values: no ldap_attribute defined in <univention.connector.attribute instance at 0x7fa7082aaea8>, we unset the key organisation in the ucs-object
13.08.2010 16:01:31,594 LDAP (WARNING): __set_values: no ldap_attribute defined in <univention.connector.attribute instance at 0x7fa7082aaf80>, we unset the key street in the ucs-object
13.08.2010 16:01:31,619 LDAP (WARNING): __set_values: no ldap_attribute defined in <univention.connector.attribute instance at 0x7fa7082b5560>, we unset the key postcode in the ucs-object
13.08.2010 16:01:31,667 LDAP (WARNING): __set_values: no ldap_attribute defined in <univention.connector.attribute instance at 0x7fa7082b5050>, we unset the key profilepath in the ucs-object
13.08.2010 16:01:31,689 LDAP (WARNING): __set_values: no ldap_attribute defined in <univention.connector.attribute instance at 0x7fa7082aaf38>, we unset the key mailPrimaryAddress in the ucs-object
13.08.2010 16:01:31,689 LDAP (ERROR ): Unknown Exception during sync_to_ucs
13.08.2010 16:01:31,689 LDAP (ERROR ): – for details see /var/log/univention/connector-tracebacks.log –
13.08.2010 16:01:31,690 LDAP (WARNING): sync to ucs was not successfull, save rejected
13.08.2010 16:01:31,690 LDAP (WARNING): object was: CN=tribu01,OU=Users School,DC=school,DC=zeus
13.08.2010 16:01:31,717 LDAP (WARNING): __set_values: no ldap_attribute defined in <univention.connector.attribute instance at 0x7fa7082aae18>, we unset the key firstname in the ucs-object
13.08.2010 16:01:31,718 LDAP (ERROR ): Unknown Exception during sync_to_ucs
13.08.2010 16:01:31,718 LDAP (ERROR ): – for details see /var/log/univention/connector-tracebacks.log –
13.08.2010 16:01:31,719 LDAP (WARNING): sync to ucs was not successfull, save rejected
13.08.2010 16:01:31,719 LDAP (WARNING): object was: CN=John Doe,OU=Users School,DC=school,DC=zeus
and in /var/log/unnivention/connector-tracebacks.log
Fri Aug 13 16:06:30 2010
File “/usr/lib/python2.4/site-packages/univention/connector/init.py”, line 973, in sync_to_ucs
result = self.add_in_ucs(property_type, object, module, position)
File “/usr/lib/python2.4/site-packages/univention/connector/init.py”, line 859, in add_in_ucs
self.__set_values(property_type,object,ucs_object, modtype=‘add’)
File “/usr/lib/python2.4/site-packages/univention/connector/init.py”, line 821, in __set_values
set_values(self.property[property_type].post_attributes[attr_key])
File “/usr/lib/python2.4/site-packages/univention/connector/init.py”, line 804, in set_values
ucs_object[ucs_key] = []
File “/usr/lib/python2.4/site-packages/univention/admin/handlers/init.py”, line 191, in setitem
raise univention.admin.uexceptions.valueRequired, _(‘The property %s is required’) % self.descriptions[key].short_description
valueRequired: The property Primary E-Mail Address is required
File “/usr/lib/python2.4/site-packages/univention/connector/init.py”, line 811, in __set_values
set_values(self.property[property_type].attributes[attr_key])
valueRequired: The property First name is required
And in /var/log/univention/connector-status.log
Sync 39 rejected changes from AD to UCS
restored 0 rejected changes
Any thoughts?
