[SOLVED] Samba sysvol ACLs for error
Hi, I have migrated by DC backup to DC master. Everything works fine but getting this error in System diagnostic:
WARNING: Samba sysvol ACLs for error.
samba-tool ntacl sysvolcheck returned a problem with the sysvol ACLs.
STDOUT:
ERROR(): uncaught exception - (2, ‘No such file or directory’)
File “/usr/lib/python2.7/dist-packages/samba/netcmd/init.py”, line 185, in _run
return self.run(*args, **kwargs)
File “/usr/lib/python2.7/dist-packages/samba/netcmd/ntacl.py”, line 317, in run
lp, mask_msad_differences)
File “/usr/lib/python2.7/dist-packages/samba/provision/init.py”, line 2119, in checksysvolacl
direct_db_access, mask_msad_differences)
File “/usr/lib/python2.7/dist-packages/samba/provision/init.py”, line 2047, in check_gpos_acl
direct_db_access=direct_db_access, service=SYSVOL_SERVICE)
File “/usr/lib/python2.7/dist-packages/samba/ntacls.py”, line 116, in getntacl
xattr.XATTR_NTACL_NAME)
New when i run: samba-tool ntacl sysvolreset succeeded.
STDOUT:
set_nt_acl_conn: init_files_struct failed: NT_STATUS_OBJECT_NAME_NOT_FOUND
WARNING 2019-05-04 12:16:29,643 pid:6287 /usr/lib/python2.7/dist-packages/samba/provision/init.py #1608: Unable to set ACL O:LAG:BAD:P(A;OICI;0x001f01ff;;;BA)(A;OICI;0x001200a9;;;SO)(A;OICI;0x001f01ff;;;SY)(A;OICI;0x001200a9;;;AU)(A;OICI;0x001301bf;;;PA) on /var/lib/samba/sysvol/walkwel.lan/Policies
WARNING 2019-05-04 12:16:29,646 pid:6287 /usr/lib/python2.7/dist-packages/samba/provision/init.py #1608: Unable to set ACL O:DAG:DAD:P(A;OICI;0x001f01ff;;;DA)(A;OICI;0x001f01ff;;;EA)(A;OICIIO;0x001f01ff;;;CO)(A;OICI;0x001f01ff;;;DA)(A;OICI;0x001f01ff;;;SY)(A;OICI;0x001200a9;;;AU)(A;OICI;0x001200a9;;;ED) on /var/lib/samba/sysvol/walkwel.lan/Policies/{31B2F340-016D-11D2-945F-00C04FB984F9}
WARNING 2019-05-04 12:16:29,648 pid:6287 /usr/lib/python2.7/dist-packages/samba/provision/init.py #1608: Unable to set ACL O:DAG:DAD:P(A;OICI;0x001f01ff;;;DA)(A;OICI;0x001f01ff;;;EA)(A;OICIIO;0x001f01ff;;;CO)(A;OICI;0x001f01ff;;;DA)(A;OICI;0x001f01ff;;;SY)(A;OICI;0x001200a9;;;AU)(A;OICI;0x001200a9;;;ED) on /var/lib/samba/sysvol/walkwel.lan/Policies/{6AC1786C-016F-11D2-945F-00C04FB984F9}
WARNING 2019-05-04 12:16:29,650 pid:6287 /usr/lib/python2.7/dist-packages/samba/provision/init.py #1608: Unable to set ACL O:DAG:DAD:P(A;OICI;0x001f01ff;;;DA)(A;OICI;0x001f01ff;;;EA)(A;OICIIO;0x001f01ff;;;CO)(A;OICI;0x001f01ff;;;DA)(A;OICI;0x001f01ff;;;SY)(A;OICI;0x001200a9;;;AU)(A;OICI;0x001200a9;;;ED) on /var/lib/samba/sysvol/walkwel.lan/Policies/{36BE4171-DECC-453B-BE8B-ABA0F621EF8A}
Solved by moving policy folder from old server to new and then re-fix from diagnose center.
