Hello, I would like to activate the greylist but selectively and only in special conditions using the regular expressions on the IP address:
/etc/postfix/client_check.pcre:
/(\-.+){4}$/ check_greylist
/(\..+){4}$/ check_greylist
/(^|[0-9.x_-])(abo|br(e|oa)dband|cabel|(hk)?cablep?|catv|cbl|cidr|d?client2?|cust(omer)?s ? | dhcp | dial? (in | up)? | d [iu] p | [aSX]? DSLD? | dyn (a (dsl | mic)?)? | home | in-addr | modem (cable)? | (a)? pool | ppp | ptr | rev | static | Board | YahooBB [0-9] {12} | c [[: alnum:]] {6} (\. [az] {3})? \ .virtua | [1-9] Cust [0-9] + | AC [AZ] [0-9A-F] {5} \. ipt | pcp [0-9] {6} pcs | S0106 [[: alnum:]] {12} \. [az] {2}) [0-9.x _-] / check_greylist
/^ Unknown $ / check_greylist
modify the file /etc/postfix/main.cf as follows:
smtpd_restriction_classes = check_greylist
check_greylist = check_policy_service inet:127.0.0.1:10023
Additionally the entry check_policy_service inet:127.0.0.1:10023 in smtpd_recipient_restrictions = will be replaced by check_client_access regexp:/etc/postfix/check_client_greylist:
permit_mynetworks
permit_sasl_authenticated
reject_invalid_hostname
how to apply this conf to ucs 4.2?
regargs.
