Hey,
After migrating UCS 4.2 to 4.3, I noticed in the registry that these values remain old.
Best Regards,
Michael Voigt
Hey,
Best Regards,
Michael Voigt
Hey,
what’s the output of the following commands:
univention-app info
univention-ldapsearch -b cn=samba4,cn=apps,cn=univention,$(ucr get ldap/base) dn univentionAppID univentionAppVersion
dpkg -l | grep '^ii.*samba'
Kind regards,
mosu
Hey,
follows below:
root@servidor:~# univention-app info
UCS: 4.3-0 errata0
Installed: cups=2.2.1 dhcp-server=12.0 kde=5.8 nagios=4.3 pkgdb=11.0 printquota=10.0 samba4=4.7 self-service=3.0
Upgradable:
___________________________________________________________________________________
root@servidor:~# univention-ldapsearch -b cn=samba4,cn=apps,cn=univention,$(ucr get ldap/base) dn univentionAppID univentionAppVersion
# extended LDIF
# LDAPv3
# base <cn=samba4,cn=apps,cn=univention,dc=goes,dc=lan> with scope subtree
# filter: (objectclass=*)
# requesting: dn univentionAppID univentionAppVersion
# samba4, apps, univention, goes.lan
dn: cn=samba4,cn=apps,cn=univention,dc=goes,dc=lan
# samba4_4.6, samba4, apps, univention, goes.lan
dn: univentionAppID=samba4_4.6,cn=samba4,cn=apps,cn=univention,dc=goes,dc=lan
univentionAppID: samba4_4.6
univentionAppVersion: 4.6
# search result
search: 3
result: 0 Success
# numResponses: 3
# numEntries: 2
root@servidor:~# dpkg -l | grep '^ii.*samba'
ii python-samba 2:4.7.5-1A~4.3.0.201803140017 amd64 Python bindings for Samba
ii samba 2:4.7.5-1A~4.3.0.201803140017 amd64 SMB/CIFS file, print, and login server for Unix
ii samba-common 2:4.7.5-1A~4.3.0.201803140017 all common files used by both the Samba server and client
ii samba-common-bin 2:4.7.5-1A~4.3.0.201803140017 amd64 Samba common files used by both the server and the client
ii samba-dsdb-modules 2:4.7.5-1A~4.3.0.201803140017 amd64 Samba Directory Services Database
ii samba-libs:amd64 2:4.7.5-1A~4.3.0.201803140017 amd64 Samba core libraries
ii samba-vfs-modules 2:4.7.5-1A~4.3.0.201803140017 amd64 Samba Virtual FileSystem plugins
ii univention-nagios-samba 3.0.0-1A~4.3.0.201712120054 amd64 nagios plugin for UCS samba
ii univention-newsid 9.0.0-1A~4.3.0.201712120245 amd64 UCS - generate a new samba sid
ii univention-samba-local-config 12.0.1-1A~4.3.0.201802271540 all UCS - UCR Extensions for configuration of local shares
ii univention-samba4 7.0.2-6A~4.3.0.201803011601 amd64 UCS - Samba4 integration package
ii univention-samba4-sysvol-sync 7.0.2-6A~4.3.0.201803011601 all UCS - Samba4 sysvol synchronization
Hey,
thanks. Please try running univentoin-app register samba4 and univention-run-join-scripts Then look at the UCR variables and the output of that LDAP search command again and see if the numbers are updated.
Kind regards,
mosu
Mosu,
I did what you said.
Now he’s set the record. Maybe this is not happening automatically when upgrading from 4.2 to 4.3
Best Regards,
Michael
The app registration is not done automatically when updating to UCS 4.3, that is a known issue. It will be fixed with an errata update.
Wonderful
Best regards,
Michael Voigt
