Request for feedback: Script to setup SSO for Kopano WebApp (through OpenID Provider App)
Super stuff. I hope some others give it a try & broaden your feedback. Thanks again.
is the procedure with the script still up to date? I ask because the posts are from April 2020 and a lot is happening at Meet (IMHO).
Or has this already been integrated into UCS/Kopnao?
Does this also work with the DeskApp? I use this with the intranet plugin to use Meet.
with best
sven
Yes, the above way is still the recommended one. This will be natively integrated once there is a new “Kopano One” app, but that will still take some time as I first need to get the container setup right.
Yes and no. The DeskApp currently overrides the oidc login and still does the old password based login. So when using Meet in the intranet plugin you likely need to login twice. There is progress however to bring oidc support to DeskApp.
