I installed the Radius server component on UCS. I have a DD-WRT access point that I am trying to configure to use it.
It simply will not connect. When I go into the command line and use Freeradius in debug mode (freeradius -X) I get the following:
[code]rad_recv: Access-Request packet from host 192.168.1.7 port 32768, id=1, length=139
User-Name = “user1”
NAS-IP-Address = 192.168.1.7
Called-Station-Id = “c0c1c0474946”
Calling-Station-Id = “206e9c0ff2c5”
NAS-Identifier = “c0c1c0474946”
NAS-Port = 56
Framed-MTU = 1400
NAS-Port-Type = Wireless-802.11
EAP-Message = 0x020000120162737472696e6766656c6c6f77
Message-Authenticator = 0xb532875636a3da4bc652717dee2a4275
Executing section authorize from file /etc/freeradius/sites-enabled/default
± entering group authorize {…}
++[preprocess] returns ok
++[chap] returns noop
++[mschap] returns noop
[ntdomain] No ‘’ in User-Name = “user1”, looking up realm NULL
[ntdomain] No such realm “NULL”
++[ntdomain] returns noop
[eap] EAP packet type response id 0 length 18
[eap] No EAP Start, assuming it’s an on-going EAP conversation
++[eap] returns updated
++[files] returns noop
[ldap] performing user authorization for user1
[ldap] expand: (uid=%{mschap:User-Name:-%{User-Name}}) -> (uid=user1)
[ldap] expand: dc=ldap,dc=company,dc=com -> dc=ldap,dc=company,dc=com
[ldap] ldap_get_conn: Checking Id: 0
[ldap] ldap_get_conn: Got Id: 0
[ldap] attempting LDAP reconnection
[ldap] (re)connect to dc.ldap.company.com:7389, authentication 0
[ldap] starting TLS
[ldap] bind as cn=dc,cn=dc,cn=computers,dc=ldap,dc=company,dc=com/wRSdNHNOfbqEteEZDqJ7 to dc.ldap.company.com:7389
[ldap] waiting for bind result …
[ldap] Bind was successful
[ldap] performing search in dc=ldap,dc=company,dc=com, with filter (uid=user1)
[ldap] No default NMAS login sequence
[ldap] looking for check items in directory…
[ldap] sambaNTPassword -> NT-Password == 0x4533384245373333354337463634464139324643463144454643333844464344
[ldap] looking for reply items in directory…
WARNING: No “known good” password was found in LDAP. Are you sure that the user is configured correctly?
[ldap] user user1 authorized to use remote access
[ldap] ldap_release_conn: Release Id: 0
++[ldap] returns ok
++[expiration] returns noop
++[logintime] returns noop
[pap] Normalizing NT-Password from hex encoding
[pap] WARNING: Auth-Type already set. Not setting to PAP
++[pap] returns noop
Found Auth-Type = EAP
Executing group from file /etc/freeradius/sites-enabled/default
± entering group authenticate {…}
[eap] EAP Identity
[eap] processing type tls
[tls] Initiate
[tls] Start returned 1
++[eap] returns handled
Sending Access-Challenge of id 1 to 192.168.1.7 port 32768
EAP-Message = 0x010100061920
Message-Authenticator = 0x00000000000000000000000000000000
State = 0x40cb472f40ca5e44a1f9ec6e89b43f0d
Finished request 0.
Going to the next request
Waking up in 4.9 seconds.
Cleaning up request 0 ID 1 with timestamp +27
WARNING: !!!
WARNING: !! EAP session for state 0x40cb472f40ca5e44 did not finish!
WARNING: !! Please read http://wiki.freeradius.org/Certificate_Compatibility
WARNING: !!!
Ready to process requests.
^C
root@dc:~#[/code]
Thanks in advance
