I just recently installed a new Slave DC to my network and for some reason Radius doesn’t seem to be working. I have made sure to configure the clients.conf that is located under the 3.0 directory with the appropriate settings, but it doesn’t seem to be authenticating. I currently have two other slaves that are working fine, although those were upgraded from 4.2 to 4.3 so I am not sure what the issue could be. Any help would be greatly appreciated.
Hey,
in general the FreeRadius daemon writes information to /var/log/freeradius/radius.log. Have you taken a look at it?
If that isn’t enough: the FreeRadius daemon provides quite a lot of useful debug output if you enable it:
- First, stop the running daemon (e.g.
systemctl stop freeradius.service). - Then start it manually with the
-doption:freeradius -d -x - Try authenticating with your device.
Again, the output will go to the aforementioned log file.
Kind regards,
mosu
