Hello everyone,
in UCS 5.0.2 it is not possible to enable or configure user quotas on an existing partition I have moved over from an old file server to the new one.
I can see the partitions under ‘Filesystem quota’ but when I try to ebable it I get the error message:
An error has occurred:
The request could not be executed.
Error message from server:
Activation of quota support has failed:/dev/dm-1: Partition is not mounted
When I do it in the CLI using the command /usr/sbinquotaon /mountpath
the quota works and with the command quota --show-mntpoint USERNAME
I can also see all for quota configured mount pathes and the consumption of the user.
Is there a bug in UCS?
Thank you in advance.
Best regards
Hendrik Dreyer
