QA: Is a cn-based LDAP base valid, and why does UDM show name: None?
Question
Is an LDAP base such as cn=example,dc=intranet valid in UCS? Why does udm container/dc list show name: None for this base object?
Answer
An LDAP base can begin with cn=. It does not have to consist exclusively of dc= components. The value cn=example,dc=intranet is already a complete Distinguished Name (DN).
The UDM property name is mapped to the LDAP attribute dc. If no name is found there, the container/dc module checks l, o, c, ou, and dc. It does not use cn as a fallback.
Consequently, a base object containing cn but none of these other naming attributes can appear as name: None. This does not mean that the literal value None is stored in LDAP.
This mapping was verified in the UCS 5.0-10 release source and the UCS 5.2-7 source branch.
Verification
Read the naming attributes directly from the LDAP base object:
univention-ldapsearch -LLL -b "$(ucr get ldap/base)" -s base '(objectClass=*)' objectClass cn dc l o c ou
If the result contains cn but none of dc, l, o, c, or ou, the missing UDM name is explained by this mapping.
Is a correction necessary?
The display alone does not establish a broken LDAP base or an upgrade blocker. Do not add naming attributes solely to populate the UDM field, and do not change ldap/base manually.
Compatibility of the complete environment, including connected applications, should be verified by testing the planned upgrade in an isolated copy.
