Q&A: Is it Possible to See or Manage DHCP Leases Through UMC?
Qeustion
Is it possible to see or manage DHCP leases through UMC?
Answer
Currently (UCS 4.3) this feature is not implemented but registered as feature request.
You might use the “vote” functionality in this Bug to increase priority.
Additionally you can check current leases only on command line in the file /var/lib/dhcp/dhcpd.leases.
