Question
I need to sort the portals entries and bring the items for multiple categories in the desired order. Doing this via the UMC works, but I need a CLI version with udm - what’s the correct syntax?
Answer
The syntax for setting the portals entries has changed to the content attribute (portalEntriesOrder is deprecated since Aug. 2018) and for the value a JSON object is needed to have the desired order. An example:
eval "$(ucr shell ldap/base)"
json_content=$(cat << END
"cn=service,cn=categories,cn=portal,cn=univention,${ldap_base}",
"cn=teacherconsole,cn=portal,cn=univention,${ldap_base}",
"cn=horde,cn=portal,cn=univention,${ldap_base}"
"cn=admin,cn=categories,cn=portal,cn=univention,${ldap_base}",
"cn=umc-domain,cn=portal,cn=univention,${ldap_base}",
"cn=nagios,cn=portal,cn=univention,${ldap_base}",
"cn=backupserver,cn=portal,cn=univention,${ldap_base}"
END
udm settings/portal modify \
--dn "cn=domain,cn=portal,cn=univention,${ldap_base}" \
--set content="${json_content}"
Please note: The value of content has to be a valid JSON Object. You can check the syntax i.e. with https://www.jslint.com/
