Q&A: Can I reset POSIX ACLs for a folder?
Question
Answer
Yes, you can.
Option 1
Remove all ACLs.
Use tar from this article to remove all ACLs.
Option 2
Transfer ACLs from a folder with correct ACLs.
First, configure the ACLs on a working folder as they should be. Afterwards, transfer ACLs from this folder to the target one:
getfacl folder_ok | setfacl --set-file=- /path/to/brokenfolder
See Also
Mastodon
