Liebes Support-Team,
ich habe einen neuen UCS-Server aufgesetzt, eine neue Domäne eingerichtet und erhalte überraschender weise nach einer Anmeldung am Webclient die folgende Fehlermeldung.
Haben Sie einen Hinweis zur Problemlösung?
Vg Robert B.
Die Initialisierung des Moduls ist fehlgeschlagen:
File "/usr/lib/pymodules/python2.7/univention/management/console/protocol/modserver.py", line 178, in _recv
self.handle(msg)
self.handle(msg)
self.handle(msg)
self.handle(msg)
self.handle(msg)
File "/usr/lib/pymodules/python2.7/univention/management/console/protocol/modserver.py", line 290, in handle
self.__handler.init()
File "/usr/lib/pymodules/python2.7/univention/management/console/modules/udm/__init__.py", line 157, in init
self.settings = UDM_Settings()
File "/usr/lib/pymodules/python2.7/univention/management/console/modules/udm/udm_ldap.py", line 886, in __init__
self.read()
File "/usr/lib/pymodules/python2.7/univention/management/console/modules/udm/udm_ldap.py", line 889, in read
self._read_directories()
File "/usr/lib/pymodules/python2.7/univention/management/console/modules/udm/udm_ldap.py", line 88, in _decorated
return method(*args, **kwargs)
File "/usr/lib/pymodules/python2.7/univention/management/console/ldap.py", line 140, in _decorated
kwargs[loarg], kwargs[poarg] = lo, po = getter()
File "/usr/lib/pymodules/python2.7/univention/management/console/ldap.py", line 130, in getter
conn = connection()
File "/usr/lib/pymodules/python2.7/univention/management/console/ldap.py", line 53, in connection
bind(lo)
File "/usr/lib/pymodules/python2.7/univention/management/console/modules/udm/__init__.py", line 173, in bind_user_connection
super(Instance, self).bind_user_connection(lo)
File "/usr/lib/pymodules/python2.7/univention/management/console/base.py", line 353, in bind_user_connection
lo.lo.bind(self._user_dn, self._password)
File "/usr/lib/pymodules/python2.7/univention/uldap.py", line 165, in bind
self.lo.simple_bind_s(self.binddn, self.__encode_pwd(self.bindpw))
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 879, in simple_bind_s
res = self._apply_method_s(SimpleLDAPObject.simple_bind_s,*args,**kwargs)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 860, in _apply_method_s
return func(self,*args,**kwargs)
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 215, in simple_bind_s
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 476, in result3
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 483, in result4
File "/usr/lib/python2.7/dist-packages/ldap/ldapobject.py", line 106, in _ldap_call
result = func(*args,**kwargs)
INVALID_CREDENTIALS: Die Initialisierung des Moduls ist fehlgeschlagen: Traceback (most recent call last):
self.handle(msg)
self.handle(msg)
self.handle(msg)
self.handle(msg)
self.read()
conn = connection()
bind(lo)
self.handle(msg)
self.handle(msg)
self.handle(msg)
self.read()
conn = connection()
bind(lo)
self.handle(msg)
self.handle(msg)
self.read()
conn = connection()
bind(lo)
self.handle(msg)
self.read()
conn = connection()
bind(lo)
INVALID_CREDENTIALS: {'desc': 'Invalid credentials'}
