i have upgrade my ucs server to 4.3 yesterday. since then, the radius server isn’t working anymore correctly as i cannot login to my wifi anymore.According to app center, i have version 5.0 installed.
If i try to restart the server, i get the following response:
If i execute the mentioned command, i get the following response:
Another threat had mentioned to execute dpkg -l | grep radius which returns the following for me:
Kind Regards,
Tobias Lorentz
Hey,
the first screenshot shows that you’re trying to restart the daemon while you’re a regular user, tobias, and not root. Try prefixing the command with sudo. Also try getting into the habit of using systemctl for daemon control instead of running scripts in /etc/init.d manually.
Generally the second screenshot shows that the daemon seems to be running (that’s what the Active: line indicates). If authentication doesn’t work, then it’s not because the daemon isn’t running.
Note that due to the upgrade to Freeradius 3 additional manual steps have to be taken after the upgrade:
- The release notes state that you may have to re-add your clients.
- Paths have changed. Before the upgrade the client configuration file was located at
/etc/freeradius/clients.conf, but now it’s in sub-directory: /etc/freeradius/3.0/clients.conf
Kind regards,
mosu
Hi Mosu,
thank you very much. Filling the new clients.conf fixed the problem.
Kind Regards,
Tobi
