Problems with integration of kopano 8.7.0
My UCS with kopano 8.7.0, z-push, webapp and nextcloud is well working with only two problems:
-in the App Center kopano-core isn‘t shown
-in the user management console some things for making some kopano settings are missing. Administrator is shown as user and no field for changing this.
Since today there is the update of UCS to 4.4.0 but it would eventually be better to repair the problems above first. Unfortunately i have no idea how to do it. Someone else? Maybe Felix?
Heiko
Could be the same as with Kopano-Server, Ldap - Invalid credentials
The information from https://wiki.z-hub.io/display/K4U/Debugging+Kopano+on+Univention would be helpful (this article also lists a way to just re-register the app at the end).
PS: there have been a few similar reports here on the forum where the app was partially removed because of missing dependencies. These dependencies have been fixed at the beginning of january, so I am wondering what could be the cause now).
Thanks for your answer
I‘ve checked kopano-ldap.secret, machine.secret and /etc/kopano/ldap.cfg. All passwords are equal.
root@server2:~# dpkg -l | grep -w ‘kopano4ucs|kopano-server-packages|kopano-webapp|z-push-kopano’
ii kopano-webapp 3.5.3.2209+89.1 all New and improved WebApp for Kopano
ii kopano-webapp-plugin-desktopnotifications 2.0.2.23+28.3 all Kopano WebApp Desktop notifications plugin
ii kopano-webapp-plugin-filepreviewer 2.1.0.26+20.4 all Kopano File previewer plugin
ii kopano-webapp-plugin-files 2.1.5.305+93.1 all Adds Files functionality to Kopano enabling access to WebDAV and other files backends.
ii kopano-webapp-plugin-filesbackend-owncloud 2.1.0.87+41.1 all Adds Owncloud specific functionality to Kopano Files plugin.
ii kopano-webapp-plugin-filesbackend-smb 2.1.0.50+30.1 all Adds Samba specific functionality to Kopano Files plugin.
ii kopano-webapp-plugin-folderwidgets 3.5.3.2209+89.1 all Kopano WebApp folder widgets plugin
ii kopano-webapp-plugin-mdm 2.1.0.97+33.1 all Kopano WebApp MDM plugin
ii kopano-webapp-plugin-smime 2.2.1.223+22.1 all Kopano WebApp S/MIME plugin
ii kopano-webapp-plugin-spell 2.0.0.19+37.3 all Kopano WebApp Spellchecker plugin
ii kopano-webapp-plugin-spell-de-de 2.0.0.3+34.3 all Kopano WebApp Spellchecker German dictionary plugin
ii kopano-webapp-plugin-spell-en 2.0.0.1+34.3 all Kopano WebApp Spellchecker English dictionary plugin
ii kopano-webapp-plugin-spell-nl 2.0.0.1+35.3 all Kopano WebApp Spellchecker Dutch dictionary plugin
ii kopano-webapp-plugin-titlecounter 3.5.3.2209+89.1 all Kopano WebApp Titlecounter plugin
ii kopano-webapp-plugin-webappmanual 3.5.3.2209+89.1 all Kopano WebApp Manual plugin
rc kopano4ucs 1.5.13 all Kopano4ucs integration package for Univention Corporate Server
ii kopano4ucs-lib 1.5.13 all Library package for common Kopano4ucs functions
ii kopano4ucs-schema 1.5.13 all LDAP schema for the Kopano4ucs integration
ii kopano4ucs-udm 1.5.13 all UDM extensions for the Kopano4ucs integration
ii kopano4ucs-webapp 1.5.13 all Kopano4ucs kopano-webapp integration package for Univention Corporate Server
ii kopano4ucs-z-push 1.4.18 all Meta package for Z-Push installation
ii z-push-kopano 2.4.5+0-0 all Z-Push for Kopano
ii z-push-kopano-gabsync 2.4.5+0-0 all GAB sync for Kopano
univention-app info
UCS: 4.3-3 errata452
Installed: fetchmail=6.3.26 kopano-webapp=3.4.22.1782 letsencrypt=1.2.2-8 samba4=4.7 z-push-kopano=2.4.4 4.1/nextcloud=14.0.6-1
Upgradable:
root@server2:~# ucr dump | grep kopano/cfg
kopano/cfg/admin/default_store_locale: de_DE.UTF-8
kopano/cfg/gateway/imaps_enable: yes
kopano/cfg/gateway/imaps_listen: *:993
kopano/cfg/gateway/pop3s_enable: yes
kopano/cfg/gateway/pop3s_listen: *:995
kopano/cfg/gateway/ssl_certificate_file: /etc/kopano/ssl/cert.pem
kopano/cfg/gateway/ssl_private_key_file: /etc/kopano/ssl/private.key
kopano/cfg/ical/icals_enable: yes
kopano/cfg/ical/icals_listen: *:8443
kopano/cfg/ical/server_timezone: @&@/etc/timezone@&@
kopano/cfg/ical/ssl_certificate_file: /etc/kopano/ssl/cert.pem
kopano/cfg/ical/ssl_private_key_file: /etc/kopano/ssl/private.key
kopano/cfg/ldap.propmap/0x3004001E: description
kopano/cfg/ldap.propmap/0x3A06001E: givenName
kopano/cfg/ldap.propmap/0x3A08001E: telephoneNumber
kopano/cfg/ldap.propmap/0x3A09001E: homePhone
kopano/cfg/ldap.propmap/0x3A11001E: sn
kopano/cfg/ldap.propmap/0x3A16001E: o
kopano/cfg/ldap.propmap/0x3A17001E: title
kopano/cfg/ldap.propmap/0x3A18001E: departmentNumber
kopano/cfg/ldap.propmap/0x3A19001E: roomNumber
kopano/cfg/ldap.propmap/0x3A1C001E: mobile
kopano/cfg/ldap.propmap/0x3A21001E: pager
kopano/cfg/ldap.propmap/0x3A27001E: l
kopano/cfg/ldap.propmap/0x3A29001E: street
kopano/cfg/ldap.propmap/0x3A2A001E: postalCode
kopano/cfg/ldap.propmap/0x8005001E: secretary
kopano/cfg/ldap/ldap_authentication_method: bind
kopano/cfg/ldap/ldap_bind_passwd: @&@/etc/kopano-ldap.secret@&@
kopano/cfg/ldap/ldap_bind_user: @%@ldap/hostdn@%@
kopano/cfg/ldap/ldap_emailaddress_attribute: mailPrimaryAddress
kopano/cfg/ldap/ldap_emailaliases_attribute: mailAlternativeAddress
kopano/cfg/ldap/ldap_group_search_filter: (&(kopanoAccount=1)(objectClass=kopano-group))
kopano/cfg/ldap/ldap_groupmembers_attribute: uniqueMember
kopano/cfg/ldap/ldap_groupmembers_attribute_type: dn
kopano/cfg/ldap/ldap_groupmembers_relation_attribute:
kopano/cfg/ldap/ldap_nonactive_attribute: kopanoSharedStoreOnly
kopano/cfg/ldap/ldap_quota_multiplier: 1048576
kopano/cfg/ldap/ldap_search_base: @%@ldap/base@%@
kopano/cfg/ldap/ldap_sendas_relation_attribute: uidNumber
kopano/cfg/ldap/ldap_uri: ldap://@%@ldap/server/name@%@:@%@ldap/server/port@%@/
kopano/cfg/ldap/ldap_user_search_filter: (kopanoAccount=1)
kopano/cfg/ldap/ldap_user_type_attribute_value: kopano-user
kopano/cfg/ldap/ldap_user_unique_attribute: entryUUID
kopano/cfg/server/local_admin_users: root kopano
kopano/cfg/server/mysql_database: kopano
kopano/cfg/server/mysql_host: localhost
kopano/cfg/server/mysql_password: @&@/etc/kopano-mysql.secret@&@
kopano/cfg/server/mysql_port: 3306
kopano/cfg/server/mysql_user: kopanoDbUser
kopano/cfg/server/run_as_group: kopano
kopano/cfg/server/run_as_user: kopano
kopano/cfg/server/server_listen: *:236
kopano/cfg/server/server_listen_tls: *:237
kopano/cfg/server/server_name: server2
kopano/cfg/server/server_ssl_ca_file: /etc/univention/ssl/ucsCA/CAcert.pem
kopano/cfg/server/server_ssl_key_file: /etc/kopano/ssl/server.pem
kopano/cfg/server/sync_gab_realtime: no
I hope the blocks above show something.
I had updated kopano in December with your 30day-key because of problems with some mails under iOS. A few days later there was the automatic update to 8.7.0. In the weeks after this i found some error with „mdb_equality_candidates: (o) not indexed“ which i could fix with the help of your knowledge base. But i never looked into the user management.
Top shows me a running kopano-server, -search, -spooler and -monitor but also python2.7. Is this right?
Heiko
they are still equal, but since kopano4ucs is not installed they will not be anymore once the ldap password is rotated.
In Kopano Core Update 8.6.9 to 8.7.0 at UCS 4.2-5 w/ Kopano repo: missing/old integration package - #11 by fbartels I have explained the steps to figure out why kopano4ucs is not installed any longer.
Hello
after
univention-app register kopano-core --do-it
and
apt-get -s -o Debug::pkgProblemResolver=yes install kopano4ucs
i get
root@server2:~# apt-get -s -o Debug::pkgProblemResolver=yes install kopano4ucs
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen… Fertig
Paket kopano4ucs ist nicht verfügbar, wird aber von einem anderen Paket
referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
wurde oder nur aus einer anderen Quelle verfügbar ist.
E: Für Paket »kopano4ucs« existiert kein Installationskandidat.
root@server2:~# apt-cache policy python-bsddb3
python-bsddb3:
Installiert: (keine)
Installationskandidat: 6.1.0-1+b2
Versionstabelle:
6.1.0-1+b2 500
500 updates.software-univention.de 4.3-3/amd64/
Output of univention-install kopano4ucs kopano-server-packages
OK:124 updates.software-univention.de 4.3-3-errata/amd64/ Release
Holen:125 Index of /univention-repository/4.3/maintained/component kopano-core_20181112170522/all/ Packages [6.678 B]
Holen:126 Index of /univention-repository/4.3/maintained/component kopano-core_20181112170522/amd64/ Packages [26,3 kB]
Es wurden 37,3 kB in 20 s geholt (1.790 B/s).
Abhängigkeitsbaum wird aufgebaut…
Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
nicht erstellt wurden oder Incoming noch nicht verlassen haben.
Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
Die folgenden Pakete haben unerfüllte Abhängigkeiten:
kopano-server-packages : Hängt ab von: kopano-backup (= 8.6.8.10-0+23.1) aber 8.7.0.0-0+1.1 soll installiert werden
Hängt ab von: kopano-dagent (= 8.6.8.10-0+23.1) aber 8.7.0.0-0+1.1 soll installiert werden
Hängt ab von: kopano-gateway (= 8.6.8.10-0+23.1) aber 8.7.0.0-0+1.1 soll installiert werden
Hängt ab von: kopano-ical (= 8.6.8.10-0+23.1) aber 8.7.0.0-0+1.1 soll installiert werden
Hängt ab von: kopano-monitor (= 8.6.8.10-0+23.1) aber 8.7.0.0-0+1.1 soll installiert werden
Hängt ab von: kopano-search (= 8.6.8.10-0+23.1) aber 8.6.9.0-0+24.1 soll installiert werden
Hängt ab von: kopano-server (= 8.6.8.10-0+23.1) aber 8.7.0.0-0+1.1 soll installiert werden
Hängt ab von: kopano-spooler (= 8.6.8.10-0+23.1) aber 8.7.0.0-0+1.1 soll installiert werden
Hängt ab von: kopano-utils (= 8.6.8.10-0+23.1) aber 8.7.0.0-0+1.1 soll installiert werden
E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
And now?
this is strange. especially since he can afterwards find the package.
I spun up an old system with 8.6.8 and tested the upgrade to 8.7.0. for me this works.
Apart from the one command with kopano4ucs, what does the following return?
apt-get -s -o Debug::pkgProblemResolver=yes kopano-server-packages
Has the eval key expired by now maybe?
You mean apt-get -s -o Debug::pkgProblemResolver=yes install kopano-server- packages ?
root@server2:~# apt-get -s -o Debug::pkgProblemResolver=yes install kopano-server-packages
Paket kopano-server-packages ist nicht verfügbar, wird aber von einem anderen Paket
You sent me the first eval key at 17.12. so it has expired. A few days ago i made a download of a file from kopano to get a new key with another email-address. This key i wrote in kopano/repo/password with the GUI of UCR
since the kopano4ucs package is not installed i would say that the custom repo stuff is also not active (you could check e.g. /etc/apt/sources.list.d/kopano-core.list to verify this).
No real idea what could be going wrong here. Like I said on my system this works. Maybe make another attempt at univention-app register kopano-core --do-it && univention-install kopano4ucs?
There is no kopano-core.list
root@server2:/# ls -l /etc/apt/sources.list.d
insgesamt 16
-rw-r–r-- 1 root root 3571 Mär 14 20:02 15_ucs-online-version.list
-rw-r–r-- 1 root root 1514 Mär 14 20:06 20_ucs-online-component.list
-rw-r–r-- 1 root root 871 Mär 5 23:22 kopano-webapp.list
-rw-r–r-- 1 root root 498 Dez 17 19:26 z-push.list
I add kopano-server-packages
root@server2:/# univention-app register kopano-core --do-it && univention-install kopano4ucs kopano-server-packages
Registering component for kopano-core=8.6.8.2
Creating data directories for kopano-core…
Registering UCR for kopano-core
Marking kopano-core=8.6.8.2 as installed
Adding localhost to LDAP object
OK:128 updates.software-univention.de 4.3-3-errata/amd64/ Release
You already have kopano-server-packages installed, therefore I’ve asked you in my last reply to install only the kopano4ucs package.
Sorry, i did it but forgot to publish.
root@server2:~# univention-app register kopano-core --do-it && univention-install kopano4ucs
Ign:1 http://repo.z-hub.io/z-push:/final/Univention_4.3 InRelease
OK:2 http://repo.z-hub.io/z-push:/final/Univention_4.3 Release
Ign:3 updates.software-univention.de 4.0-0/all/ InRelease
Ign:4 Index of /univention-repository/4.3/maintained/component kopano-core_20181112170522/all/ InRelease
Ign:5 updates.software-univention.de 4.0-0/amd64/ InRelease
Ign:6 Index of /univention-repository/4.3/maintained/component kopano-core_20181112170522/amd64/ InRelease
Ign:7 updates.software-univention.de 4.0-1/all/ InRelease
Ign:8 Index of /univention-repository/4.3/maintained/component letsencrypt_20190118130723/all/ InRelease
Ign:9 updates.software-univention.de 4.0-1/amd64/ InRelease
Ign:10 Index of /univention-repository/4.3/maintained/component kopano-webapp_20180921151350/all/ InRelease
Ign:11 https://download.kopano.io/supported/webapp:/final/Univention_4.3 InRelease
Ign:12 updates.software-univention.de 4.0-2/all/ InRelease
Ign:13 Index of /univention-repository/4.3/maintained/component kopano-webapp_20180921151350/amd64/ InRelease
Ign:15 updates.software-univention.de 4.0-2/amd64/ InRelease
Ign:16 Index of /univention-repository/4.3/maintained/component z-push-kopano_20180917082536/all/ InRelease
Ign:17 https://download.kopano.io/supported/files:/final/Univention_4.3 InRelease
Ign:18 updates.software-univention.de 4.0-3/all/ InRelease
Ign:19 Index of /univention-repository/4.3/maintained/component z-push-kopano_20180917082536/amd64/ InRelease
Ign:20 updates.software-univention.de 4.0-3/amd64/ InRelease
OK:21 Index of /univention-repository/4.3/maintained/component kopano-core_20181112170522/all/ Release
Ign:22 updates.software-univention.de 4.0-4/all/ InRelease
Ign:23 https://download.kopano.io/supported/mdm:/final/Univention_4.3 InRelease
OK:24 Index of /univention-repository/4.3/maintained/component kopano-core_20181112170522/amd64/ Release
Ign:25 updates.software-univention.de 4.0-4/amd64/ InRelease
OK:26 Index of /univention-repository/4.3/maintained/component letsencrypt_20190118130723/all/ Release
Ign:27 updates.software-univention.de 4.0-5/all/ InRelease
OK:28 Index of /univention-repository/4.3/maintained/component kopano-webapp_20180921151350/all/ Release
Ign:29 https://download.kopano.io/supported/smime:/final/Univention_4.3 InRelease
Ign:30 updates.software-univention.de 4.0-5/amd64/ InRelease
OK:31 Index of /univention-repository/4.3/maintained/component kopano-webapp_20180921151350/amd64/ Release
Ign:32 updates.software-univention.de 4.1-0/all/ InRelease
OK:33 Index of /univention-repository/4.3/maintained/component z-push-kopano_20180917082536/all/ Release
Ign:34 updates.software-univention.de 4.1-0/amd64/ InRelease
OK:35 Index of /univention-repository/4.3/maintained/component z-push-kopano_20180917082536/amd64/ Release
OK:36 https://download.kopano.io/supported/webapp:/final/Univention_4.3 Release
Ign:37 updates.software-univention.de 4.1-1/all/ InRelease
Ign:38 updates.software-univention.de 4.1-1/amd64/ InRelease
OK:39 https://download.kopano.io/supported/files:/final/Univention_4.3 Release
Ign:40 updates.software-univention.de 4.1-2/all/ InRelease
Ign:41 updates.software-univention.de 4.1-2/amd64/ InRelease
Ign:42 updates.software-univention.de 4.1-3/all/ InRelease
OK:43 https://download.kopano.io/supported/mdm:/final/Univention_4.3 Release
Ign:44 updates.software-univention.de 4.1-3/amd64/ InRelease
Ign:45 updates.software-univention.de 4.1-4/all/ InRelease
Ign:46 updates.software-univention.de 4.1-4/amd64/ InRelease
OK:48 https://download.kopano.io/supported/smime:/final/Univention_4.3 Release
Ign:49 updates.software-univention.de 4.1-5/all/ InRelease
Ign:50 updates.software-univention.de 4.1-5/amd64/ InRelease
Ign:51 updates.software-univention.de 4.2-0/all/ InRelease
Ign:52 updates.software-univention.de 4.2-0/amd64/ InRelease
Ign:53 updates.software-univention.de 4.2-1/all/ InRelease
Ign:54 updates.software-univention.de 4.2-1/amd64/ InRelease
Ign:55 updates.software-univention.de 4.2-2/all/ InRelease
Ign:56 updates.software-univention.de 4.2-2/amd64/ InRelease
Ign:57 updates.software-univention.de 4.2-3/all/ InRelease
Ign:58 updates.software-univention.de 4.2-3/amd64/ InRelease
Ign:59 updates.software-univention.de 4.2-4/all/ InRelease
Ign:60 updates.software-univention.de 4.2-4/amd64/ InRelease
Ign:61 updates.software-univention.de 4.2-5/all/ InRelease
Ign:63 updates.software-univention.de 4.2-5/amd64/ InRelease
Ign:64 https://updates.software-univention.de/4.3/maintained 4.3-0/all/ InRelease
Ign:65 https://updates.software-univention.de/4.3/maintained 4.3-0/amd64/ InRelease
Ign:66 https://updates.software-univention.de/4.3/maintained 4.3-1/all/ InRelease
Ign:67 https://updates.software-univention.de/4.3/maintained 4.3-1/amd64/ InRelease
Ign:68 https://updates.software-univention.de/4.3/maintained 4.3-2/all/ InRelease
Ign:69 https://updates.software-univention.de/4.3/maintained 4.3-2/amd64/ InRelease
Ign:70 https://updates.software-univention.de/4.3/maintained 4.3-3/all/ InRelease
Ign:71 https://updates.software-univention.de/4.3/maintained 4.3-3/amd64/ InRelease
Ign:72 https://updates.software-univention.de/4.3/maintained/component 4.3-3-errata/all/ InRelease
Ign:73 https://updates.software-univention.de/4.3/maintained/component 4.3-3-errata/amd64/ InRelease
OK:74 updates.software-univention.de 4.0-0/all/ Release
OK:75 updates.software-univention.de 4.0-0/amd64/ Release
OK:76 updates.software-univention.de 4.0-1/all/ Release
OK:78 updates.software-univention.de 4.0-1/amd64/ Release
OK:79 updates.software-univention.de 4.0-2/all/ Release
OK:80 updates.software-univention.de 4.0-2/amd64/ Release
OK:81 updates.software-univention.de 4.0-3/all/ Release
OK:82 updates.software-univention.de 4.0-3/amd64/ Release
OK:83 updates.software-univention.de 4.0-4/all/ Release
OK:84 updates.software-univention.de 4.0-4/amd64/ Release
OK:85 updates.software-univention.de 4.0-5/all/ Release
OK:86 updates.software-univention.de 4.0-5/amd64/ Release
OK:87 updates.software-univention.de 4.1-0/all/ Release
OK:88 updates.software-univention.de 4.1-0/amd64/ Release
OK:89 updates.software-univention.de 4.1-1/all/ Release
OK:90 updates.software-univention.de 4.1-1/amd64/ Release
OK:92 updates.software-univention.de 4.1-2/all/ Release
OK:93 updates.software-univention.de 4.1-2/amd64/ Release
OK:94 updates.software-univention.de 4.1-3/all/ Release
OK:95 updates.software-univention.de 4.1-3/amd64/ Release
OK:96 updates.software-univention.de 4.1-4/all/ Release
OK:97 updates.software-univention.de 4.1-4/amd64/ Release
OK:98 updates.software-univention.de 4.1-5/all/ Release
OK:99 updates.software-univention.de 4.1-5/amd64/ Release
OK:100 updates.software-univention.de 4.2-0/all/ Release
OK:101 updates.software-univention.de 4.2-0/amd64/ Release
OK:102 updates.software-univention.de 4.2-1/all/ Release
OK:103 updates.software-univention.de 4.2-1/amd64/ Release
OK:104 updates.software-univention.de 4.2-2/all/ Release
OK:105 updates.software-univention.de 4.2-2/amd64/ Release
OK:107 updates.software-univention.de 4.2-3/all/ Release
OK:108 updates.software-univention.de 4.2-3/amd64/ Release
OK:109 updates.software-univention.de 4.2-4/all/ Release
OK:110 updates.software-univention.de 4.2-4/amd64/ Release
OK:111 updates.software-univention.de 4.2-5/all/ Release
OK:112 updates.software-univention.de 4.2-5/amd64/ Release
OK:113 https://updates.software-univention.de/4.3/maintained 4.3-0/all/ Release
OK:114 https://updates.software-univention.de/4.3/maintained 4.3-0/amd64/ Release
OK:115 https://updates.software-univention.de/4.3/maintained 4.3-1/all/ Release
OK:116 https://updates.software-univention.de/4.3/maintained 4.3-1/amd64/ Release
OK:117 https://updates.software-univention.de/4.3/maintained 4.3-2/all/ Release
OK:118 https://updates.software-univention.de/4.3/maintained 4.3-2/amd64/ Release
OK:119 https://updates.software-univention.de/4.3/maintained 4.3-3/all/ Release
OK:120 https://updates.software-univention.de/4.3/maintained 4.3-3/amd64/ Release
OK:121 https://updates.software-univention.de/4.3/maintained/component 4.3-3-errata/all/ Release
OK:123 https://updates.software-univention.de/4.3/maintained/component 4.3-3-errata/amd64/ Release
kopano4ucs : Hängt ab von: kopano-server-packages soll aber nicht installiert werden
Ah, I think I know what’s wrong here (at least I have an idea). Its a bit of a “chicken and egg” problem.
  • you already have 8.7.0 installed
  • when you now install the app, this in the background wants to install kopano4ucs
  • kopano4ucs has the dependency on kopano-server-packages (any version)
  • at time of install only the app repository with 8.6.8 is available
  • kopano-server-packages has a hard dependency on packages from the same version
  • so it wants to install kopano-server-packages 8.6.8, which fails since you have already something newer installed
Workaround would be to manually configure a repository that has 8.7.0 (or newer) and then install the app again.
If you would tell me how to do this i‘ll drink a beer for you :slight_smile:
This is as simple as
echo "deb https://$(ucr get kopano/repo/username):$(ucr get kopano/repo/password)@download.kopano.io/supported/core:/8.7/Univention_4.3/ /" >> /etc/apt/sources.list
And then apt-get install kopano-core ?
no, the same command as above:
Many, many thanks for your work.
The app center shows kopano-core again (8.6.8.2 but this isn‘t a problem, isn‘t it?) and the kopano section in UCM looks also good again.
Some notices in syslog with „mdb_equality_candidates: (userOptionsPreset) not indexed“ but these are no problem to correct.
Heiko
Not a problem at all and actually expected.
that is no Kopano ldap attribute, must come from somewhere else.
That‘s right. It is corrected now by the entry of Christian Voelker in the knowledge base.
Many thanks
