yesterday I had some trouble to install a new Slave in an existing UCS environment.
The versions of DC-, Backup- and Memberserver where all 4.4-4-errata 587 (they are up-to-date according to “software update”).
The version of the ESXi or ISO download file is 4.4-4 errata613.
May be my problems result from the different versions ?
1st I tried to install via ESX-ova which resulted in a lot of failures:
got access only via ssh . Otherwise I received SSL errors after installation which couldn’t fixed from me (same issuer but different certificates). The new machine was joined, but no AD samba modules installed and/or running and a lot more.
So I switched to the ISO download and re-installed the UCS Slave.
After, no user Administrator was installed so the access to the WebGUI was only possible via user “root”.
Furthermore in the GUI the Server Modules are not displayed as with the UCS DC and UCS Backup Server (no access to DHCP-, DNS- LDAP & more - which are all properly installed). Only “join to domain” is availible.
It seems that the GUI think its a Member Server, but
~# ucr get server/role
domaincontroller_slave
instead of
Server is joined without failures.
So I thinks that this is not standard ?
How can I fix that ?
