When trying to prepare the release update to UCS 5.2, I received the following message:
root@bskw-s-2020:~# univention-upgrade
Starting univention-upgrade. Current UCS version is 5.0-9 errata1212
Checking for package updates: none
Checking for app updates: none
Checking for release updates: The update to UCS 5.1-0 is blocked because the component ‘opsi_20240925338247’ is marked as required.
none
How do I get the block solved opsi has already been completely uninstalled ?
Just did the upgrade on my 2 nodes from the UI panel.
Only an error message at the beginning, saying that there are 3 nagios configurations that are not supportet anymore: 24x7, WorkingHours, NonWorkingHours. Just deleted, and the upgrade works like a charm.
I will try to answer some of the questions mentioned here.
First you are right, some legacy objects like Nagios entries have to be removed manually. We decided to not do this automatically to make it explicit that this is being removed now and custom configurations may need to be saved or solved with an alternative - But removing them is the right thing to do.
I understand your confusion, the command may be a bit misleading here: You cannot update to a certain erratum (the last number), but only to a certain patch level. The right parameter would be:
