Problem with self service ad/reset/password and ad/reset/username
Dear all,
we are trying to set up self service for the user to be able to reset the password.
The sending of mails is working, but when it comes to reset the password the UCS server always complains about the fields ad/reset/password and ad/reset/username not beeing filled properly.
I´ve tried to fill them with our Windows domain administrator and the appropriate password, but now way. We cann not get rid of the system complaining about these two fields.
Is there any special syntax for the username or are there any other fields which have to be filled?
Best regards and thanks in advance
Andreas
as I have no environment for comparison I would recommend to read the description of the UCRV, for example by using ucr search ad/reset.
According to https://forge.univention.org/bugzilla/show_bug.cgi?id=44867 the UCRV ad/reset/password needs a filename which contains the password.
hth,
Dirk
