After upgrading to 5.2.0 the daemon sssd-pac crashes after running a few hours. The demon itself can not be restarted, restarting sssd does not solve the problem. Only the reboot of the server activates sssd-pac. But only for a few hours, than it crashes again.
In the syslogs I found the info: sssd_pac[1319361]: /usr/libexec/sssd/sssd_pac: error while loading shared librari es: libndr.so.3: cannot open shared object file: No such file or directory
The package samb-libs contains the files libndr.so.[1|2|5] but no libndr.so.3.
Hello!
had the same issue after upgrade, except it never activates, not even after a reboot. same error message about libndr.so.3 - on a clean install it works normally.
I compared the broken system with the clean install.
Neither of them have said file in /lib/x86_64-linux-gnu
only libndr.so.5 and libndr.so.5.0.0
How could this be solved? And if not, what potential impact could this have on the updated system?
Thank you for any ideas and help!
