Problem: Warning About Integrity Check in Owncloud
Your Owncloud app reports issues about the integrity of some files.
Environment
Owncloud has introduced code signing and therefor reports code not being valid.
Unfortunately, the reason is not easy to determine. It might be:
  • Issue with the check itself
  • Outdated database containing the file signatures
  • Wrong code due to virus or similar
Check your files again and report possible issues to Owncloud support.
