Problem: UCS Server Sends Packages Through the Wrong Gateway
Your UCS server has multiple network interface cards (NICs) and should send it’s outgoing packages through the default gateway instead of the gateways connected to the other networks.
Make sure your NICs are configured for static IP instead of getting their IP addresses through DHCP. When getting an IP address through DHCP the existing default gateway gets overwritten with the one received by DHCP.
