Problem: Owncloud Does Not Find The LDAP-Base
It is not possible to login to Owncloud any more. Owncloud complains about having lost the connection to LDAP.
Investigation
First, check DNS settings:
ping <NAME-OF-YOUR-UCS>
Then check if DNS settings work inside the Docker container as well:
univention-app shell owncloud
If one of the above (or both) commands fail check you DNS configuration. In case the server is not found, simply add it to your DNS server in use.
Afterwards Owncloud can resolve the name and find the LDAP-base.
