@externa: Danke, kannte ich tatsächlich noch nicht.
@pixel: Danke. Hier mal die Ausgaben:
root@mx-a:~# pvdisplay
WARNING: Device /dev/sdb3 has size of 132839424 sectors which is smaller than corresponding PV size of 132842160 sectors. Was device resized?
One or more devices used as PVs in VG vg_ucs have changed sizes.
--- Physical volume ---
PV Name /dev/sdb5
VG Name vg_ucs
PV Size 55,42 GiB / not usable 4,00 MiB
Allocatable yes (but full)
PE Size 4,00 MiB
Total PE 14187
Free PE 0
Allocated PE 14187
PV UUID Lm3Feo-bcpe-rJCU-mTyx-zVIQ-YWgw-r2ybMi
PV Name /dev/sdb3
VG Name vg_ucs
PV Size 63,34 GiB / not usable 4,34 MiB
PE Size 4,00 MiB
Total PE 16215
Free PE 0
Allocated PE 16215
PV UUID XcZerR-jZIr-erPW-MmtJ-GGF1-YX7s-JlmqWe
der nächste
root@mx-a:~# lvdisplay
--- Logical volume ---
LV Path /dev/vg_ucs/root
LV Name root
VG Name vg_ucs
LV UUID 9YYSn1-oXsK-dTMQ-STTi-u1Ev-TwhA-bJ1xQh
LV Write Access read/write
LV Creation host, time ,
LV Status available
# open 1
LV Size 115,09 GiB
Current LE 29463
Segments 2
Allocation inherit
Read ahead sectors auto
- currently set to 256
Block device 254:0
LV Path /dev/vg_ucs/swap_1
LV Name swap_1
VG Name vg_ucs
LV UUID YSWm9f-51me-kL3E-CSP6-YpeY-i0Zs-dVpa2Z
LV Status available
# open 2
LV Size 3,67 GiB
Current LE 939
Segments 1
Allocation inherit
Block device 254:1
und noch einer
root@mx-a:~# vgdisplay
--- Volume group ---
VG Name vg_ucs
System ID
Format lvm2
Metadata Areas 2
Metadata Sequence No 10
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 2
Open LV 2
Max PV 0
Cur PV 2
Act PV 2
VG Size 118,76 GiB
PE Size 4,00 MiB
Total PE 30402
Alloc PE / Size 30402 / 118,76 GiB
Free PE / Size 0 / 0
VG UUID eFSTei-1u6B-FFj2-ANGc-Y2fm-EbDn-wwV6QL
root@mx-a:~# pvs
PV VG Fmt Attr PSize PFree
/dev/sdb3 vg_ucs lvm2 a-- 63,34g 0
/dev/sdb5 vg_ucs lvm2 a-- 55,42g 0
root@mx-a:~# lvs
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
root vg_ucs -wi-ao---- 115,09g
swap_1 vg_ucs -wi-ao---- 3,67g
root@mx-a:~# vgs
VG #PV #LV #SN Attr VSize VFree
vg_ucs 2 2 0 wz--n- 118,76g 0
Ich werde nicht mehr schlau draus… Wahrscheinlich hab ich tatsächlich Tomaten auf den Augen. Fakt ist, zuerst war es eine 60GB SSD mit 55,42 GB LV. Diese war voll bis auf ca. 4,9 GB, welche ich durch löschen diverser Logs und Docker purge frei bekommen hatte.
Dann auf 128 GB SSD geklont, dort zusätzliche Partition angelegt, pvcreate und lvextend -l +100%FREE auf maximale Größe vergrößert. Zuletzt mit resizefs das Dateisystem auf den letzten Stand gebracht. Trotzdem keine freien PE… wie verhext. Es ist keine weitere Aktivität auf dem Rechner passiert ausser ein paar Logs, ursprünglich waren noch 4,9 GB frei aber keine PE.
Grüße
