Problem: Mails Are Not Send
The UCS server can not send emails.
Environment
There is a firewall between the UCS server and the Internet.
In /var/log/mail.log you might see entries similar to the following:
Oct 28 10:17:47 ucs postfix/smtp[1437]: connect to mx01.gmx.net[212.227.17.5]:25: Connection timed out
Oct 28 10:18:17 ucs postfix/smtp[1437]: connect to mx00.gmx.net[212.227.15.9]:25: Connection timed out
Make sure your firewall is not blocking port 25 outwards. You can verify the remote port is accessible through the telnet command:
root@ucs:~# telnet mx01.gmx.net 25
Trying 212.227.17.5...
Connected to mx01.emig.gmx.net.
Escape character is '^]'.
Another possibility to verify is the use of traceroute:
root@ucs:~# traceroute -n -T -p 25 mx01.emig.gmx.net
traceroute to mx01.emig.gmx.net (212.227.17.5), 30 hops max, 60 byte packets
 1 192.168.20.10  0.314 ms  0.253 ms  0.218 ms
 2 80.157.204.86  21.330 ms  21.989 ms  21.978 ms
 3 212.227.122.16  25.646 ms  25.557 ms  25.675 ms
 4 212.227.17.5  24.264 ms  24.054 ms  23.759 ms
