LDAP searches return different results on the Primary and a Backup Directory Node. Existing objects may not be found on the Backup, or searches remain slow even after running slapindex.
A remaining /etc/ldap/slapd.d/cn=config.ldif can cause slapindex, when called without an explicit configuration file, to use a different database configuration instead of /etc/ldap/slapd.conf. Rebuilding those indexes does not repair the indexes used by the UCS LDAP server.
Investigation
Check whether the alternative configuration is still present:
ls -l /etc/ldap/slapd.d/cn=config.ldif
If present, slapindex without -f may use this configuration instead of the UCS configuration.
Run as root on the affected Backup. Ensure a current LDAP backup exists. LDAP will be unavailable on this server during the rebuild.
Stop LDAP and disable the unintended configuration. Do not overwrite an existing .DISABLED file:
systemctl stop slapd.service
mv -i /etc/ldap/slapd.d/cn=config.ldif \
/etc/ldap/slapd.d/cn=config.ldif.DISABLED
Rebuild the domain database indexes using the UCS configuration explicitly:
slapindex -f /etc/ldap/slapd.conf -b "$(ucr get ldap/base)"
Using -f /etc/ldap/slapd.conf also selects the correct configuration without renaming the file.
After the rebuild completes successfully, start LDAP:
systemctl start slapd.service
Repeat the previously failing search locally on both servers. For example:
univention-ldapsearch -LLL '(uid=testuser)' dn source
Replace testuser with an affected account. Confirm that both servers return the expected object and search performance has recovered.
