Problem: Join Fails
Problem: Join of a New Server Fails
You attempt to join a UCS server to your domain but the join process fails.
You notice:
root@ucs-slave:~# univention-join
univention-join: joins a computer to an ucs domain
copyright (c) 2001-2019 Univention GmbH, Germany
Enter DC Master Account : administrator
Enter DC Master Password:Search
 DC Master:                                          done
Check DC Master:
* Join failed!                                                           *
* Contact your system administrator                                      *
* Message:  Please visit https://help.univention.com/t/8842 for common problems during the join and how to fix them -- The ssh-login to administrator@ucs.multi.ucs failed with " ". Please make sure the account administrator exists and is a member of the Domain Admins group!
Environment
Your servers (including master) are running as virtual machines on a physical host.
Step 1
Test manually:
root@ucs:~# echo -n "ADMINPASSWORD">pwd.txt
root@ucs:~# univention-ssh -timeout 3 ./pwd.txt Administrator@ucs-101.artietee.intranet ls ; echo $?
In case you get back a “1” permanently you should check your master for performance issues as it is reacting too slow.
