I have mistakenly renamed an OU via AD; I will revert that as soon as possible
Environment
UCS4.x with AD-Connector
You must wait until the whole OU tree is renamed. Then you can rename the OU again.
Depending on the count of Objects in the tree this may take a while.
Root Cause
If you change the name of an OU the path for all objets below will also change and all Object must synchronized via AD-connector.
