Problem: Despite the setting "Allow unknown clients" at the DHCP pool, no IP addresses are distributed to unknown devices
Despite the setting “Allow unknown clients” at the DHCP pool, no IP addresses are distributed to unknown devices.
Investigation:
The dhcp configuration is stored in ldap. To make the used configuration visible you can enable the “debug” in
/etc/dhcp/dhcpd.conf
ldap-debug-file "/var/log/dhcp-ldap-startup.log";
If the configuration looks like this with a subnet and a pool:
------8< ----------------------------------------
subnet 10.200.43.0 netmask 255.255.252.0 {
option routers 10.200.43.1;
option domain-name "schein.me";
option domain-name-servers 10.200.0.10;
deny unknown-clients;
allow bootp;
pool {
range 10.200.46.250 10.200.46.254;
deny known clients;
allow unknown clients;
deny dynamic bootp clients;
max-lease-time 86400;
default-lease-time 28800;
---------------->8----------------------
The problem is that the default policy defined for the service (cn=default-allow-verbieten) is inherited by all subnets and the definition no longer applies to the individual pools.
The definition at the service must not be set to make the confiugration work for the defined pools.
