Problem: Connections (as a client) to let's encryted domains from UCS not trusted
With UCS 4.4-8 errata 1057 an below access of Let’s Encrypt signed sites is not possible since 2021-10-01 as the certificate is not trusted.
You can test it by using tool like curl or wget.
root@dc1:~# curl https://dc1.fqdn-host.de
curl: (60) SSL certificate problem: certificate has expired
Please install errata 1059 and 1060 that will fix the problem.
In some cases you need to remove the old R3-certificate and refresh ca certs:
rm /usr/local/share/ca-certificates/lets-encrypt-r3.crt
update-ca-certificates  --fresh
Maybe it also needs a refresh for lets encrypt
/usr/share/univention-letsencrypt/refresh-cert-cron
Search tags: letsencrypt
Mastodon
