Problem bei Update auf Zarafa4UCS 7.2
Ich habe gestern versucht, das Update auf Zarafa4UCS 7.2.1-51838 upzudaten. Nach dem Update funktionierte dann die Anmeldung via webapp nicht mehr. Ich hab dann versucht, lt. Angabe in diesem Forum, alle Zarafa-Prozesse zu killen und dann hab ich das Update wiederholt. Leider immer noch nicht erfolgreich.
Im server.log gibt es folgende Einträge:
Sat Mar 26 13:16:11 2016: Starting zarafa-server version 7,1,14,51822, pid 4443 Sat Mar 26 13:16:11 2016: Listening for TCP connections on port 236 Sat Mar 26 13:16:11 2016: Listening for SSL connections on port 237 Sat Mar 26 13:16:11 2016: Listening for priority pipe connections on /var/run/zarafa-prio Sat Mar 26 13:16:11 2016: Listening for pipe connections on /var/run/zarafa Sat Mar 26 13:16:11 2016: Connection to database 'zarafa' succeeded Sat Mar 26 13:16:11 2016: zarafa-licensed is running, but no license key was found. Not all commercial features will be available. Sat Mar 26 13:16:13 2016: Loading searchfolders Sat Mar 26 13:16:15 2016: Startup succeeded on pid 4449 Sat Mar 26 13:38:34 2016: Disconnect from LDAP because search error Can't contact LDAP server Sat Mar 26 13:49:08 2016: Previous message logged 7 times Sat Mar 26 13:49:08 2016: Shutting down. Sat Mar 26 13:49:08 2016: Still waiting for 8 threads to exit Sat Mar 26 13:49:15 2016: Server shutdown complete. Sat Mar 26 13:49:45 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 9662 Sat Mar 26 13:49:50 2016: [error ] Error while connecting to search on file:///var/run/zarafa-search Sat Mar 26 13:55:01 2016: [error ] Previous message logged 33 times Sat Mar 26 13:55:01 2016: [error ] Disconnect from LDAP because search error Can't contact LDAP server Sat Mar 26 13:56:16 2016: [ notice] Server shutdown complete. Sat Mar 26 14:21:29 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 12127 Sat Mar 26 14:21:35 2016: [error ] Error while connecting to search on file:///var/run/zarafa-search Sat Mar 26 14:23:36 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 12446 Sat Mar 26 14:23:36 2016: [fatal ] Unable to bind to port 236: Die Adresse wird bereits verwendet. This is usually caused by another process (most likely another zarafa-server) already using this port. This program will terminate now. Sat Mar 26 14:24:30 2016: [error ] Previous message logged 33 times Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276600 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276595 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276590 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276585 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276580 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276575 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276570 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276565 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276560 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276555 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276550 Sat Mar 26 14:24:30 2016: [error ] SerializeObject failed with error code 0x80000004 for object 276545 Sat Mar 26 14:24:36 2016: [ notice] Server shutdown complete. Sat Mar 26 14:29:35 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 4355 Sat Mar 26 14:29:40 2016: [error ] Error while connecting to search on file:///var/run/zarafa-search Sat Mar 26 14:44:26 2016: [error ] Previous message logged 99 times Sat Mar 26 14:44:26 2016: [error ] Disconnect from LDAP because search error Can't contact LDAP server Sat Mar 26 14:46:24 2016: [ notice] Server shutdown complete. Sat Mar 26 15:11:32 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 7820 Sat Mar 26 15:11:38 2016: [error ] Error while connecting to search on file:///var/run/zarafa-search Sat Mar 26 15:13:06 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 8259 Sat Mar 26 15:13:06 2016: [fatal ] Unable to bind to port 236: Die Adresse wird bereits verwendet. This is usually caused by another process (most likely another zarafa-server) already using this port. This program will terminate now. Sat Mar 26 15:21:50 2016: [error ] Previous message logged 33 times Sat Mar 26 15:21:50 2016: [fatal ] Session failed to shut down: skipping clean Sat Mar 26 16:44:32 2016: [fatal ] SQL [00000233] info: Try to reconnect Sat Mar 26 16:44:32 2016: [fatal ] ECDatabaseMySQL::Connect(): mysql connect fail 80000007 Sat Mar 26 16:44:32 2016: [fatal ] ECDatabaseMySQL::DoSelect(): query failed Sat Mar 26 16:44:32 2016: [error ] SerializeObject failed with error code 0x80000007 for object 271310 Sat Mar 26 16:44:39 2016: [ notice] Server shutdown complete. Sat Mar 26 16:47:09 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 5065 Sat Mar 26 16:47:12 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:12 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:12 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:12 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:12 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:12 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:12 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:12 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:14 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:14 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:15 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:15 2016: [error ] Error while connecting to search on file:///var/run/zarafa-search Sat Mar 26 16:47:16 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:16 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:47:16 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 16:47:16 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 16:48:36 2016: [ notice] Server shutdown complete. Sat Mar 26 16:55:25 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 8256 Sat Mar 26 16:55:26 2016: [fatal ] ECDatabaseMySQL::Connect(): mysql connect fail 80000007 Sat Mar 26 16:55:26 2016: [fatal ] Unable to connect to database: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) Sat Mar 26 16:55:26 2016: [ notice] Server shutdown complete. Sat Mar 26 16:55:53 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 8397 Sat Mar 26 16:55:53 2016: [fatal ] ECDatabaseMySQL::Connect(): mysql connect fail 80000007 Sat Mar 26 16:55:53 2016: [fatal ] Unable to connect to database: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) Sat Mar 26 16:55:53 2016: [ notice] Server shutdown complete. Sat Mar 26 17:02:05 2016: [ notice] Starting zarafa-server version 7,2,1,51838, pid 4414 Sat Mar 26 17:02:09 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 17:02:09 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 17:02:09 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 17:02:09 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 17:02:09 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 17:02:09 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 17:02:09 2016: [fatal ] Cannot instantiate user plugin: Failure connecting any of the LDAP servers Sat Mar 26 17:02:09 2016: [fatal ] Unable to instantiate user plugin Sat Mar 26 17:06:21 2016: [ notice] Server shutdown complete.
Könnt ihr mir da weiterhelfen?
LG
Helmut
Werden noch zusätzliche LOG-Daten benötigt um eine Antwort zu finden ? Ich habe die entsprechende Festplatte zwar wieder zurückgesetzt, kann das ganze aber sicherlich rekonstruieren.
Danke im Voraus.
LG
Helmut
Hab da um Zarafa-Forum gelesen, dass die letzte Version ZCP 7.2.1 final [51848] ist. Da sind schon einige Subreleases dazwischen. Kommt diese Version auch für Zarafa4UCS ? Vlt. funktioniert das ja dann ?!?
Da es hier im Forum schon 2,3 ähnliche Meldungen dazu gab: Wurden diese Zarafa-Update Probleme schon gelöst bzw. sind das wahrscheinlich nur spezifische Probleme unter bestimmten (nicht “normalen”) Umgebungsbedingungen bei diesen Zarafa Installationen?
Wir wollen nun auch einige 7.1.14 Instanzen hochziehen, dabei darf es keine gr. Ausfälle etc. geben, weswegen wir noch etwas verunsichert sind.
Danke für alle Infos,
VG Robert
Wie bereits eingangs angeführt, habe ich diese Einträge gelesen, habe jedoch damit auch keinen Erfolg erzielt.
Meine Installation wurde “normal” aus dem AppCenter heraus durchgeführt. Es ist also meiner Meinung nach keine “nicht normale” Installation sondern einfach nur OutOfTheBox.
Ich würde auch auf eine Antwort warten bzgl. einem reibungslosen Update - insbesondere auch im Hinblick auf die neue WebApp.
LG
Helmut
[quote=“zabranah”]Ich habe gestern versucht, das Update auf Zarafa4UCS 7.2.1-51838 upzudaten. Nach dem Update funktionierte dann die Anmeldung via webapp nicht mehr. Ich hab dann versucht, lt. Angabe in diesem Forum, alle Zarafa-Prozesse zu killen und dann hab ich das Update wiederholt. Leider immer noch nicht erfolgreich.
…[/quote]
für eine weitergehende Analyse wäre die Ausgabe von
dpkg -l auf der Kommandozeile hilfreich.
Außerdem die Datei /var/log/univention/management-console-module-appcenter.log (bzw. /var/log/univention/management-console-module-appcenter.log.1 …, je nachdem wo die Infos zum Update enthalten sind, am besten alle /var/log/univention/management-console-module-appcenter.* Dateien).
Das ist ein UCS 4.1-1?
Welche Systemrolle (ucr get server/role auf der Kommandozeile)
Zarafa Update von 7.1.14-51822 auf 7.2.1-51838?
Welche Apps sind installiert, nur zarafa oder noch andere, welche?
Viele Grüße
Felix Botner
Hallo, Felix,
wie bereits angesprochen habe ich die Dateien vom Update leider nicht mehr (brauchte die HDD wieder für eine Sicherung). Ich werde am Wochenende nochmals versuchen, das Update durchzuführen. Habe soeben die neuesten Updates für Univention eingespielt. Vlt. hat sich da ja was geändert.
Kann ich die LOGs evtl. auch per Mail übermitteln ?
LG und danke für die Rückmeldung
Helmut
Habe folgende Module in UCS installiert:
UCS Active Directory-kompatibler Domaincontroller
UCS DHCP-Server
UCS Druckserver (CUPS)
UCS Fetchmail
ownCloud 8.2
Z-Push for Zarafa
Zarafa Collaboration Platform
Zarafa web meetings
LG
Helmut
Ich hab gestern nochmals versucht, das Update von Zarafa zu installieren. Der Erfolg war derselbe wie beim letzten Mal: die Installation wird anscheinend nicht abgeschlossen und ich kann mich bei Zarafa nicht anmelden.
Die Meldungen habe ich als ZIP angehängt.
Danke im Voraus für eure HIlfe.
Helmut
zarafa.zip (66.7 KB)
ich habe das Update auf 7.2 nun hinter mir. Der Server ist ebenfalls eingefroren. Nach dem Neustart lief zarafa-server nicht mehr und dementsprechend auch keine WebApp, Outlook etc.
Wieso auch immer musste man bei Zarafa die Lizenz von 7.1 auf 7.2 konvertiren. Obwohl ich die neuen Daten in die base + cal Dateien eingetragen habe wollte der zarafa-server nicht starten (angeblich zu viele Clients, obwohl eine gültige Lizenz angezigt wurde). Irgendwann so nach dem vierten Neustart ist zarafa-server angelaufen.
Ich kann es trotzdem nicht nachvollziehen warum ich die Lizenz konvertiren musste! Und bis der Server das verstanden hat vergingen zwei Stunden!
Wie wird die Zarafa-Lizenz konvertiert ?
Wenn Sie das Update aus der UMC machen dann wird da ein Link angezeigt. der geht auf portal.zarafa.com/
Ach ja und wenn man die Lizenz konvertiert hat gibt es kein zurück mehr auf 7.1
Ja, dass 7.2 einen neuen Schlüssel benötigt ist so erwartet (und steht ja auch in der Update Readme, welche das Appcenter anzeigt).
Einen Weg zurück auf 7.1 gäbe es aber weiterhin, da der alte 7.1er Schlüssel dadurch nicht seine Funktion verliert.
@zabranah
Bei dir sehe ich grundsätzlich zwei Probleme. Zum einen Steigt das das db-upgrade-addressbook-entryids-delegate.pl Skript mit einem Fehler aus (das wird nur für Updates von 7.1.11 benötigt. Schon länger kein Update gefahren?)
15.04.16 19:31:51.483  MODULE      ( PROCESS ) : "my" variable %cache masks earlier declaration in same scope at /usr/share/zarafa4ucs/db-upgrade-addressbook-entryids-delegate.pl line 251.
zum Anderen gibt es dann noch die Fehlermeldung mit “unable to instantiate user plugin”. Hier würde es helfen, wenn du deine Konfig hier einmal hochladen könntest. Vermutlich würde ein “ucr commit /etc/zarafa” (da bin ich aber nicht ganz syntaxfest, die Konfigdateien sollen einmal neu geschrieben werden) das Problem beheben.
Hallo
wobei ich mir hier nicht sicher bin, ob das db-upgrade-addressbook-entryids-delegate.pl wirklich schon durch ist. Laut management-console-module-appcenter.log sieht es so aus, als würde das db-upgrade-addressbook-entryids-delegate.pl noch laufen (kann es sein, das das Script u.U. etwas länger braucht?). Ist das db-upgrade-addressbook-entryids-delegate.pl noch in der Prozessliste (ps aux|grep db-upgrade) zu sehen?
[quote]
zum Anderen gibt es dann noch die Fehlermeldung mit “unable to instantiate user plugin”. Hier würde es helfen, wenn du deine Konfig hier einmal hochladen könntest. Vermutlich würde ein “ucr commit /etc/zarafa” (da bin ich aber nicht ganz syntaxfest, die Konfigdateien sollen einmal neu geschrieben werden) das Problem beheben.[/quote]
Leider klappt das hier mit dem “ucr commit” nicht (die Zarafa Configs sind keine Templates, beim Setzen einer Zarafa UCR Variable wird der Wert direkt in die Zarafa Config geschrieben, das ist ein UCS spezifisches Verhalten). Folgender Bash Befehle sollte aber funktionieren. Alle UCR Variablen mit dem Prefix zarafa/cfg werden nochmal auf den aktuellen Wert gesetzt. Danach sind die Configs und UCR Variablen wieder in sync.
while read ucrv; do ucr set "$ucrv"="$(ucr get $ucrv)"; done < <(ucr search --brief zarafa/cfg | awk -F : '{print $1}')
Meine Zarafa-Version ist 7.1.14-51822 in der Community-Edition und ich möchte auf 7.2 ebenfalls Community-Edition upgraden. Alle anderen Details werde ich heute oder morgen hier posten.
Danke für eure Hilfe.
LG
Helmut
Hallo
hatte ich hier auch für einige Zeit als letzte Anzeige, obwohl die Skripts dann anscheinend klaglos weitergelaufen sind. Mal sehen, wie das Endergebnis ausschaut. Einen Snapshot gibt es jedenfalls! :wink:
nach einem Tag intensiver Tests auf allen Clients schaut alles sauber aus. Auch ActiveSync schaut gut aus!
VG,
TP
Habe jetzt gestern abend und heute auf Zarafa4UCS 7.2 upgedatet!
Das DB-Update dauerte einige Stunden, daher das “einfrieren” in Line 251. Nach dem Neustart funktionierte Zarafa zwar, allerdings gab es noch die Meldung, dass der Dienst nicht in die Domäne gejoint ist. Das funktionierte auch manuell nicht.
Nachdem ich den Befehl von fbartels eingab erledigte sich der JOIN beim Neustart von selbst (Danke an fbartels).
Nachdem bei der Kontrolle der UCS-Installation noch ein Fehler kam, führte ich dpkg --configure -a aus.
Seither funktioniert alles bestens. Auch die Webapp hab ich aktualisiert.
Herzlichen Dank für eure Rückmeldung.
LG
Helmut
