Moin
the following script 66univention-ox-usm-udm does not work. As far as I can see, all components are installed, the following log excerpt is attached
Thank you and greetings from Berlin
Ben
Mi 13. Mär 03:28:56 CET 2019
univention-join-hooks: looking for hook type "join/pre-joinscripts" on mailserver.sob.de
Found hooks:
RUNNING 66univention-ox-usm-udm.inst
2019-03-13 03:28:56.643991549+01:00 (in joinscript_init)
Object exists: cn=services,cn=univention,dc=sob,dc=de
Object exists: cn=open-xchange-mobility,cn=services,cn=univention,dc=sob,dc=de
WARNING: cannot append open-xchange-mobility to service, value exists
No modification: cn=mailserver,cn=dc,cn=computers,dc=sob,dc=de
E: object not found
Object removed: cn=open-xchange-mobility,cn=custom attributes,cn=univention,dc=sob,dc=de
Object created: cn=open-xchange-mobility,cn=custom attributes,cn=univention,dc=sob,dc=de
option --ignore-exists not recognized
EXITCODE=3
f9b7a224-f801-4627-8ba7-fa78d6ef8462
univention-join-hooks: looking for hook type "join/post-joinscripts" on mailserver.sob.de
Found hooks:
I’m somewhat confused about the name of that installation module. I have OX installed (all three apps), and neither on the server containing the installation nor on my DC Master do I have a join script by that name. Maybe it’s a remnant of an earlier version of OX.
Same problem here with one of my customers right after the update to 4.4-0:
Do 14. Mär 07:36:38 CET 2019
cp: der Aufruf von stat für ‘’ ist nicht möglich: Datei oder Verzeichnis nicht gefunden
Do 14. Mär 07:37:29 CET 2019
univention-join-hooks: looking for hook type “join/pre-joinscripts” on mailserver.mail.foo.local
Found hooks:
2019-03-14 07:37:30.189864549+01:00 (in joinscript_init)
Object exists: cn=services,cn=univention,dc=mail,dc=foo,dc=local
Object exists: cn=open-xchange-mobility,cn=services,cn=univention,dc=mail,dc=foo,dc=local
No modification: cn=mailserver,cn=dc,cn=computers,dc=mail,dc=foo,dc=local
E: object not found
Object removed: cn=open-xchange-mobility,cn=custom attributes,cn=univention,dc=mail,dc=foo,dc=local
Object created: cn=open-xchange-mobility,cn=custom attributes,cn=univention,dc=mail,dc=foo,dc=local
EXITCODE=3
1fee9834-5af6-4fbf-9958-2bd8a7635f8a
univention-join-hooks: looking for hook type “join/post-joinscripts” on mailserver.mail.foo.local
Found hooks:
Do 14. Mär 07:37:32 CET 2019
I can reproduce it now that I’ve installed the appropriate packages.
The problem is in /usr/lib/univention-install/66univention-ox-usm-udm.inst which uses the option --ignore-exists whereas the supported name is --ignore_exists. Simply edit that file, go to line 64:
Thanks for the report. For the record, i forwarded the report and with that i adjusted the bug category in our bugzilla. It will not be accessible without the correct permissions in our bugzilla, you may get a permission denied error.
