when adding a group into the USC front end the S4 connector reports the following:
15.11.2022 16:56:05.677 LDAP (PROCESS): sync UCS > AD: [ group] [ add] 'cn=Sware-Deploy-Lib_01,cn=groups,DC=gp01,DC=org,DC=blown-up,DC=com'
15.11.2022 16:56:06.721 LDAP (PROCESS): sync AD > UCS: [ group] [ modify] 'cn=sware-deploy-lib_01,cn=groups,dc=gp01,dc=org,dc=blown-up,dc=com'
15.11.2022 16:56:12.786 LDAP (PROCESS): sync UCS > AD: [ group] [ modify] 'cn=sware-deploy-lib_01,cn=groups,DC=gp01,DC=org,DC=blown-up,DC=com'
now there is clearly showing a case change in the S4 connector log:
so:
- is there a case change?
if so, then S4 should NOT be showing mixed case in the log - if there is NOT a case change
if there is a case change then there should be some sort of warning, or the front end should not allow mixed case
