after Migration from Zarafa to Kopano month’s ago, there is still the Zarafa WebApp listed in the UCS Portal besides the Kopano WebApp.
I didn’t find how to remove this old Zarafa-tile from the Portal.
Regards
Neobiker
Regards
Neobiker
Hello @neobiker,
you need to check the Univention Configuration Registry and then delete all remaining zarafa-webapp entries (which are below ucs/web/overview/entries/service/).
Thanks,
i deleted zarafa-webaccess entries and it worked.
