Hey,
I got a problem with getting the ownCloud Brute-Force-Protection work properly.
Installing the app wasn’t a problem and It’s also running fine but what doesn’t work right is blocking the right IP.
The Brute-Force-Protection App is checking the owncloud.log for failed Log-Ins and blocks the IP that was used. The problem is, that the only IP logged in the owncloud.log is the IP of the container ownCloud is located in and not the external IP/the IP of the User.
Is there any way to make this work properly?
Thanks in advance!
Kind Regards
jf712
