Openvpn4UCS not showing up in the menu after reinstall
That is the correct hash, so I had a close look at the listener script. While it is true, that there is no code to delete (exactly) those lines, the code to replace the lines with options configurable via the UMC uses a rather plain matching. So my guess is your hostname contains one of those options, probably ‘server’.
The code will be fixed in the upcoming version.
Thats true. The server is called “server1”.
