I only have one UCS server with master role. And not running any Let’s Ecrypt.
I have some more feedback… no solution however
After restart, i’m able to sso using internet explorer in every servers (backup and slaves) the only server that sso isn’t working is the domainmaster
After sso with internet explorer i cannot sso using chrome. -
After restart, and try with chrome: i’m able to sso in every servers (backup and slaves) the only server that sso isn’t working is the domainmaster.
After sso with chrome i cannot sso using internet explorer
Again i don’t know if that is the expected behaviour or not… but is what happen on my side
@hpz do you have more ucs servers configured? (slave or backups) so you can try sso in that servers?
hi,
no, one single ucs master.
@hpz are you able to find the “blank.json”
still the same as written before…
@hpz yep… i also don’t have that file i none os my servers… cannot understand why the sso don’t work in domainmaster
Little thumb up this post…
Anyone can help/guide how to troubleshoot the sso and why it don’t work in the domaincontroller_master but works fine in all other servers roles (backup and slaves)
Could this be related ?
The sso address is avaible via two servers (master and backup) and the windows client trying the sso via the domaincontroller_master portal the first server that respond to the sso fqdn is the ip from the backup server?
Hi there,
I had the same problem. I did the following:
univention-run-join-scripts --force --run-scripts 98univention-samba4-saml-kerberos.inst
univention-run-join-scripts --force --run-scripts 91univention-saml.inst
# In this order, it might be a bug because the password get changed in the 98 script and I got
# an invalid password error with the next command
kinit -t /etc/simplesamlphp.keytab HTTP/ucs-sso.$(ucr get domainname)@$(ucr get kerberos/realm)
# And last but not least the following, because I got an invalid certificate error under
# https://afdc.af.intra/univention/saml/
univention-run-join-scripts --force --run-scripts 92univention-management-console-web-server.inst
After that, I was able to use my client’s kerberos ticket to login.
@damrose
There might be a Bug in the guide under: Debugging the SAML Kerbeors authentication
The 98 script changes the password of the ucs-sso user and I feel like this invalidates all tickets in the samlkeytab file. So maybe the order must be 98 and then 91, but I’am not a 100% sure.
@go2sh do you run the commands in master only or in all the servers?
Thanks
Master only as I have only one server, which is also the ucs-sso server.
@go2sh well my problem is really in the master, but all others servers work fine with sso
@codedmind Mine too. My master wasn’t able to use single-singon. Can you try to open the following page:
https://{master-dns}/univention/saml
@go2sh it will ask for login. if i went to the same url but slave-dns it works (sso)
This doesn’t work
This works
Don0t know if this matters but the first print i two management/ one 301 then other 200 in the second only get one management/ with the 200 code
Can you check your ucr variable saml/idp/authsource on the master if it is univention-negotiate. This would be the only thing I could imagine.
@go2sh yep is univention- negotiate
