Very strange behavior. I don’t know since when, but with 4.4-6 errata796 I cannot mount NFS share anymore, with or without kerberos doesn’t matter. Any suggestion?
Hi hidalgo,
I am unfortunately no Exprte. What says then:
systemctl status nfs-server.service
Am Client:
showmount -e [Servername]
Use the -vvv option for the mount command. Do you get errors here?Are there any error messages in the logfile on the server?
with best
sven
I got something like
showmount -e fp-files
Export list for fp-files:
/home *
but I get
mount -vvv -t nfs4 -o sec=krb5p fp-files:/home /mnt
mount.nfs4: timeout set for Tue Nov 10 08:47:00 2020
mount.nfs4: trying text-based options 'sec=krb5p,vers=4.2,addr=12.45.67.8,clientaddr=12.45.67.9'
mount.nfs4: mount(2): Permission denied
mount.nfs4: access denied by server while mounting fp-files:/home
Alltough it seems that something is wrong with Kerberos, I got the same error without sec=krb5p
can you mount the share without Kerberos?
As I mentioned before. Neither works without Kerberos.
What kind of client is it? Ubuntu? version?
How did you take the client into the domain? UCS join script or ADS join?
Now I got it running again. I don’t know exactly what it was. After a restart I missed the the NFS-kerberos-ticket in the key tab. So I added it again and now it works again as it should.
