Nextcloud SMB index
i use Nextcloud and SMB Share on univention. I create a SMB Share on univention and add this share via Webgui to Nextcloud user. Working with the files in Nextcloud works good. The Problem is, when i add files via smb, Nextcloud did not display these files at all. For example when i add 100 files via smb,
nextcloud only shows 30.
there is a good post in the nextcloud forum, see: https://help.nextcloud.com/t/synchronize-files-moved-to-nextcloud-directory-not-using-nextcloud-software/4488
Best,
Bernd
