Nextcloud and the HSTS issue
Hi, despite the fact of setting the UCS variables for HSTS, by using the recommendations and posts on this forum, it stays saying that it’s not enabled.
root@k4ucs:~# ucr search hsts
apache2/hsts/includeSubDomains: yes
 Applies HSTS policy also to subdomains if set to 'yes'.
apache2/hsts/max-age: 15552000
 Time in seconds of how long web browsers will cache and enforce the HSTS policy on the host. Defaults to '10886400' - which are 18 weeks.
apache2/hsts: yes
 Enable HTTP Strict Transport Security (HSTS) by setting this variable to 'yes'. 'apache2/force_https' should be enabled additionally to take full advantage of HSTS.
On the Nextcloud Settings page:
* The "Strict-Transport-Security" HTTP header is not set to at least "15552000" seconds. For enhanced security, it is recommended to enable HSTS as described in the [security tips ↗](https://docs.nextcloud.com/server/15/go.php?to=admin-security).
* Your web server is not properly set up to resolve "/.well-known/caldav". Further information can be found in the [documentation](https://docs.nextcloud.com/server/15/go.php?to=admin-setup-well-known-URL).
* Your web server is not properly set up to resolve "/.well-known/carddav". Further information can be found in the [documentation](https://docs.nextcloud.com/server/15/go.php?to=admin-setup-well-known-URL).
On the reference file:
root@k4ucs:~# cat /etc/apache2/sites-enabled/default-ssl.conf
#          univention-config-registry.
#          Please edit the following file(s) instead:
#          univention-config-registry ueberschrieben werden.
#          Bitte bearbeiten Sie an Stelle dessen die folgende(n) Datei(en):
#       /etc/univention/templates/files/etc/apache2/sites-available/ssl.d/00start
#       /etc/univention/templates/files/etc/apache2/sites-available/ssl.d/10hsts
#       /etc/univention/templates/files/etc/apache2/sites-available/ssl.d/10univention-appcenter
#       /etc/univention/templates/files/etc/apache2/sites-available/ssl.d/99end
<IfModule mod_ssl.c>
<VirtualHost *:443>
        IncludeOptional /etc/apache2/ucs-sites.conf.d/*.conf
        SSLEngine on
        SSLProxyEngine on
        SSLProxyCheckPeerCN off
        SSLProxyCheckPeerName off
        SSLProxyCheckPeerExpire off
        #SetEnvIf User-Agent ".*MSIE.*" nokeepalive ssl-unclean-shutdown
        ### To enable special log format for HTTPS-access
        # LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-agent}i\" %p" combinedssl
        # CustomLog /var/log/apache2/access.log combinedssl     ## with port number
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
        ProxyPass /nextcloud http://127.0.0.1:40000/nextcloud retry=0
        ProxyPassReverse /nextcloud http://127.0.0.1:40000/nextcloud
        ProxyPass /wordpress https://127.0.0.1:40002/wordpress retry=0
        ProxyPassReverse /wordpress https://127.0.0.1:40002/wordpress
</VirtualHost>
</IfModule>
Anyone has some idea how to solve this permanently?
Regards
JG
Ich habe das gleiche Problem festgestellt
My guess is that this is simply a false positive on Nextcloud’s end; it probably cannot detect that the proxy server (Apache on the Docker host) is adding those headers.
