Nextcloud 17.0.1-0 installation Fehler
Moin zusammen,
ich habe ein Problem mit UCS Version 4.4-3 errata413 und Nextcloud 17.0.1-0.
Die installation schlägt fehl:
Ein Fehler ist aufgetreten: Registering schema file activation failed: {u’VEC-UCS01’: {u’cn=nextcloud,cn=ldapschema,cn=univention,dc=KH,dc=Local’: u’handler start’, u’cn=univention-app,cn=ldapschema,cn=univention,dc=KH,dc=Local’: u’active’, u’cn=66univention-appcenter_app,cn=ldapacl,cn=univention,dc=KH,dc=Local’: u’active’}} /usr/share/univention-appcenter/apps/nextcloud/nextcloud.schema failed
Weitere Hinweise finden Sie in der folgenden Logdatei auf den beteiligten Systemen:
/var/log/univention/appcenter.log
Außerdem kann ich beim Join Script nicht die deinstallation von der Kaputten installation reparieren.
Running pre-joinscripts hook(s): done
Running 01univention-ldap-server-init.inst skipped (already executed)
Running 02univention-directory-notifier.inst skipped (already executed)
Running 03univention-directory-listener.inst skipped (already executed)
Running 04univention-ldap-client.inst skipped (already executed)
Running 05univention-bind.inst skipped (already executed)
Running 08univention-apache.inst skipped (already executed)
Running 10univention-ldap-server.inst skipped (already executed)
Running 11univention-heimdal-init.inst skipped (already executed)
Running 11univention-pam.inst skipped (already executed)
Running 15univention-directory-notifier-post.inst skipped (already executed)
Running 15univention-heimdal-kdc.inst skipped (already executed)
Running 18python-univention-directory-manager.inst skipped (already executed)
Running 20univention-directory-policy.inst skipped (already executed)
Running 20univention-join.inst skipped (already executed)
Running 22univention-directory-manager-rest.inst skipped (already executed)
Running 26univention-nagios-common.inst skipped (already executed)
Running 26univention-samba.inst skipped (already executed)
Running 30univention-appcenter.inst skipped (already executed)
Running 30univention-nagios-client.inst skipped (already executed)
Running 31univention-nagios-ad-connector.inst skipped (already executed)
Running 33univention-portal.inst skipped (already executed)
Running 34univention-management-console-server.inst skipped (already executed)
Running 35univention-appcenter-docker.inst skipped (already executed)
Running 35univention-management-console-module-adconnector.skipped (already executed)
Running 35univention-management-console-module-appcenter.inskipped (already executed)
Running 35univention-management-console-module-diagnostic.iskipped (already executed)
Running 35univention-management-console-module-ipchange.insskipped (already executed)
Running 35univention-management-console-module-join.inst skipped (already executed)
Running 35univention-management-console-module-lib.inst skipped (already executed)
Running 35univention-management-console-module-mrtg.inst skipped (already executed)
Running 35univention-management-console-module-quota.inst skipped (already executed)
Running 35univention-management-console-module-reboot.inst skipped (already executed)
Running 35univention-management-console-module-services.insskipped (already executed)
Running 35univention-management-console-module-setup.inst skipped (already executed)
Running 35univention-management-console-module-sysinfo.instskipped (already executed)
Running 35univention-management-console-module-top.inst skipped (already executed)
Running 35univention-management-console-module-ucr.inst skipped (already executed)
Running 35univention-management-console-module-udm.inst skipped (already executed)
Running 35univention-management-console-module-updater.instskipped (already executed)
Running 35univention-server-overview.inst skipped (already executed)
Running 36univention-management-console-module-apps.inst skipped (already executed)
Running 40univention-postgresql.inst skipped (already executed)
Running 40univention-virtual-machine-manager-schema.inst skipped (already executed)
Running 81univention-ad-connector.inst skipped (already executed)
Running 81univention-nfs-server.inst skipped (already executed)
Running 90univention-bind-post.inst skipped (already executed)
Running 91univention-saml.inst skipped (already executed)
Running 92univention-management-console-web-server.inst skipped (already executed)
Running 98univention-pkgdb-tools.inst skipped (already executed)
Running 51nextcloud-uninstall.uinst failed (exitcode: 3)
Running post-joinscripts hook(s): done
Die beiden Logs sind im Anhang.appcenter.log.txt (1.0 MB) join.log.txt (93.5 KB)
Ich habe selber kaum Ahnung von UCS, weil das mein Abschlussprojekt werden soll (FiSi) mit Nextcloud installation.
