I’ve installed a new USC 4.4 Master. Afert 3 days i get this error message:
16.05.19 18:21:48.636 MODULE ( PROCESS ) : Checks ucs-sso by comparing 'ucr get ucs/server/sso/fqdn' with the Location field in /usr/share/univention-management-console/saml/idp/*.xml
File "/usr/share/pyshared/univention/management/console/modules/diagnostic/plugins/04_saml_certificate_check.py", line 124, in <module>
run(0)
File "/usr/share/pyshared/univention/management/console/modules/diagnostic/plugins/04_saml_certificate_check.py", line 76, in run
test_identity_provider_certificate()
File "/usr/share/pyshared/univention/management/console/modules/diagnostic/plugins/04_saml_certificate_check.py", line 89, in test_identity_provider_certificate
for host in socket.gethostbyname_ex(sso_fqdn)[2]:
socket.gaierror: [Errno -2] Name or service not known
I read this: SAML certificate verification failed and also have done this: Renewing the SSL certificates but that did not help. Also no other UCS can join the domain. The Serves hasn’t NAT. Both have public ip-Adresses and dualstack.
If i would like to join, i get an timeout with this script:
univention-run-join-scripts --run-scripts 92univention-management-console-web-server
So what can i do?
Thanks a lot
