Need Direction Please
I’m currently setting up a univention server on my internal network, behind a firewall. I’m trying make this externally accessible but I want the sitename.com to be the webservice odoo instead of the main univention server. Can someone please advise me on documentation I can read to try make this scenario work. Thank you.
You might have a look at the UCR (Univention Config Registry).
root@ucs:~# ucr info apache2/startsite
Here you can configure the landing spot of your webserver. When pointing to odoo’s DocumentRoot the UCS-Overview and UMC (webfrontend) is still reachable by adding ‘ucs-overview/’ or ‘univention-management-console/’ to your browsers url address.
root@ucs:~# ucr set apache2/startsite=/web
This should change the behavior as expected.
since UCS 4.2
the default landing pages have changed:
  • The new Portal (former Overview) can be reached via
    /univention/portal/
  • The Univention Management Console (UMC) can now be reached via
    /univention/management/
So when changing the apache2/startsite it’s good to know, but with the new Portal functionality you now can add your own custom Tiles so deep modding probably isn’t necessary.
