Und hier der Inhalt der Managmant - Console dateien …
[code] root@ucsmaster:/var/log/univention# ls -l management-console-*.log
-rw-r----- 1 root adm 15692 Jan 25 17:07 management-console-module-appcenter.log
-rw-r----- 1 root adm 0 Apr 21 2016 management-console-module-apps.log
-rw-r----- 1 root adm 0 Jul 11 2015 management-console-module-diagnostic.log
-rw-r----- 1 root adm 590 Jan 25 17:07 management-console-module-join.log
-rw-r----- 1 root adm 0 Dez 1 06:25 management-console-module-lib.log
-rw-r----- 1 root adm 0 Nov 17 2013 management-console-module-quota.log
-rw-r----- 1 root adm 0 Dez 12 2014 management-console-module-reboot.log
-rw-r----- 1 root adm 0 Mär 7 2015 management-console-module-services.log
-rw-r----- 1 root adm 0 Jul 14 2015 management-console-module-setup.log
-rw-r----- 1 root adm 0 Jan 9 2015 management-console-module-sysinfo.log
-rw-r----- 1 root adm 0 Jan 20 2015 management-console-module-top.log
-rw-r----- 1 root adm 0 Nov 29 06:25 management-console-module-ucr.log
-rw-r----- 1 root adm 2137 Jan 25 17:07 management-console-module-udm.log
-rw-r----- 1 root adm 1836 Jan 25 17:07 management-console-module-updater.log
-rw-r----- 1 root adm 0 Jan 1 06:25 management-console-module-uvmm.log
-rw-r----- 1 root adm 26394 Jan 25 17:07 management-console-server.log
-rw-r----- 1 root adm 390 Jan 25 16:39 management-console-web-server.log
root@ucsmaster:/var/log/univention# cat management-console-module-join.log
23.01.17 09:26:29.743 DEBUG_INIT
23.01.17 09:36:31.150 MAIN ( WARN ) : Shutting down all open connections
23.01.17 09:44:32.954 DEBUG_INIT
23.01.17 09:54:48.766 MAIN ( WARN ) : Shutting down all open connections
24.01.17 14:51:21.255 DEBUG_INIT
24.01.17 15:01:23.428 MAIN ( WARN ) : Shutting down all open connections
25.01.17 16:39:28.983 DEBUG_INIT
25.01.17 16:49:32.689 MAIN ( WARN ) : Shutting down all open connections
25.01.17 16:57:37.637 DEBUG_INIT
25.01.17 17:07:39.503 MAIN ( WARN ) : Shutting down all open connections
root@ucsmaster:/var/log/univention# cat management-console-module-udm.log
23.01.17 09:26:29.727 DEBUG_INIT
23.01.17 09:26:31.242 ADMIN ( WARN ) : No settings/cn superordinate was given.
23.01.17 09:26:31.243 ADMIN ( WARN ) : No settings/cn superordinate was given.
23.01.17 09:26:33.320 ADMIN ( WARN ) : No settings/cn superordinate was given.
23.01.17 09:27:23.036 ADMIN ( WARN ) : No settings/cn superordinate was given.
23.01.17 09:37:26.207 MAIN ( WARN ) : Shutting down all open connections
23.01.17 09:44:32.729 DEBUG_INIT
23.01.17 09:44:32.997 ADMIN ( WARN ) : No settings/cn superordinate was given.
23.01.17 09:44:32.998 ADMIN ( WARN ) : No settings/cn superordinate was given.
23.01.17 09:44:33.014 ADMIN ( WARN ) : No settings/cn superordinate was given.
23.01.17 09:44:46.779 ADMIN ( WARN ) : No settings/cn superordinate was given.
23.01.17 09:54:50.480 MAIN ( WARN ) : Shutting down all open connections
24.01.17 14:51:21.259 DEBUG_INIT
24.01.17 14:51:23.692 ADMIN ( WARN ) : No settings/cn superordinate was given.
24.01.17 14:51:23.693 ADMIN ( WARN ) : No settings/cn superordinate was given.
24.01.17 14:51:24.973 ADMIN ( WARN ) : No settings/cn superordinate was given.
24.01.17 14:51:38.709 ADMIN ( WARN ) : No settings/cn superordinate was given.
24.01.17 14:52:55.828 ADMIN ( ERROR ) : Could not determine host record for name=‘ANCELOTTI’, ip=‘192.168.100.3’. Not creating pointer record.
24.01.17 14:53:44.018 ADMIN ( WARN ) : No settings/cn superordinate was given.
24.01.17 15:08:56.900 MAIN ( WARN ) : Shutting down all open connections
25.01.17 16:39:28.995 DEBUG_INIT
25.01.17 16:39:33.948 ADMIN ( WARN ) : No settings/cn superordinate was given.
25.01.17 16:42:15.315 ADMIN ( WARN ) : No settings/cn superordinate was given.
25.01.17 16:45:16.211 ADMIN ( WARN ) : No settings/cn superordinate was given.
25.01.17 17:07:37.487 MAIN ( WARN ) : Shutting down all open connections
root@ucsmaster:/var/log/univention# cat management-console-module-updater.log
23.01.17 09:26:29.700 DEBUG_INIT
23.01.17 09:36:31.168 MAIN ( WARN ) : Shutting down all open connections
23.01.17 09:44:33.243 DEBUG_INIT
23.01.17 09:54:49.039 MAIN ( WARN ) : Shutting down all open connections
24.01.17 14:51:21.241 DEBUG_INIT
24.01.17 15:01:23.451 MAIN ( WARN ) : Shutting down all open connections
25.01.17 16:49:32.060 MAIN ( WARN ) : Shutting down all open connections
25.01.17 16:57:37.661 DEBUG_INIT
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : check for updates with “dist-upgrade -s”, the returncode is 0
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : stderr=
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added univention-management-console-module-apps to the list of upgraded packages
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added univention-management-console-module-appcenter to the list of upgraded packages
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added univention-appcenter to the list of upgraded packages
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added univention-appcenter-docker to the list of upgraded packages
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added python-univention-appcenter to the list of upgraded packages
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added univention-s4-connector to the list of upgraded packages
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added python-univention-connector-s4 to the list of upgraded packages
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added univention-errata-level to the list of upgraded packages
25.01.17 16:57:58.007 NETWORK ( PROCESS ) : Added univention-management-console-module-udm to the list of upgraded packages
25.01.17 17:07:47.872 MAIN ( WARN ) : Shutting down all open connections
root@ucsmaster:/var/log/univention# cat management-console-server.log
23.01.17 09:26:26.355 AUTH ( ERROR ) : Canonicalization of username failed: Traceback (most recent call last):
File “/usr/lib/pymodules/python2.7/univention/management/console/auth.py”, line 132, in __canonicalize_username
result = lo.search(filter_format(’(&(%s=%s)(objectClass=person))’, (attr, username)), attr=[‘uid’], unique=True)
File “/usr/lib/pymodules/python2.7/univention/admin/uldap.py”, line 341, in search
elif res == 2:
ldapError: Invalid credentials
23.01.17 09:26:26.817 ACL ( PROCESS ) : Allowed UMC operations:
23.01.17 09:26:26.817 ACL ( PROCESS ) : User | Host | Flavor | Command | Options
23.01.17 09:26:26.817 ACL ( PROCESS ) : ******************************************************************************
23.01.17 09:26:26.817 ACL ( PROCESS ) : False | ucsmaster | * | appcenter/* | {}
23.01.17 09:26:26.817 ACL ( PROCESS ) : False | ucsmaster | * | apps/* | {}
23.01.17 09:26:26.817 ACL ( PROCESS ) : False | ucsmaster | * | diagnostic/* | {}
23.01.17 09:26:26.817 ACL ( PROCESS ) : False | ucsmaster | * | ip/change | {}
23.01.17 09:26:26.817 ACL ( PROCESS ) : False | ucsmaster | * | join/* | {}
23.01.17 09:26:26.817 ACL ( PROCESS ) : False | ucsmaster | * | lib/* | {}
23.01.17 09:26:26.817 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/reboot | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/shutdown | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | lib/sso/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | mrtg/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | packages/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | passwordchange/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | pkgdb/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | quota/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | reboot/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | services/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | setup/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | sysinfo/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | top/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | ucr/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | udm/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | udm/request_new_license | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | updater/* | {}
23.01.17 09:26:26.818 ACL ( PROCESS ) : False | ucsmaster | * | uvmm/* | {}
23.01.17 09:26:29.315 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘join’, ‘-s’, ‘/var/run/univention-management-console/3884-1485159989315.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
23.01.17 09:26:29.384 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘updater’, ‘-s’, ‘/var/run/univention-management-console/3884-1485159989384.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
23.01.17 09:26:29.397 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘appcenter’, ‘-s’, ‘/var/run/univention-management-console/3884-1485159989397.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
23.01.17 09:26:29.404 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘udm’, ‘-s’, ‘/var/run/univention-management-console/3884-1485159989404.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
23.01.17 09:36:31.170 MAIN ( WARN ) : Socket died (module=join)
23.01.17 09:36:31.170 MAIN ( WARN ) : Module process join died (pid: 12737, exit status: -1, signal: -1, status: -1)
23.01.17 09:36:31.170 MAIN ( WARN ) : Cleaning up requests
23.01.17 09:36:31.170 MAIN ( WARN ) : Remove inactivity timer
23.01.17 09:36:31.170 MAIN ( PROCESS ) : ModuleProcess: child died
23.01.17 09:36:31.187 MAIN ( WARN ) : Socket died (module=updater)
23.01.17 09:36:31.188 MAIN ( WARN ) : Module process updater died (pid: 12738, exit status: -1, signal: -1, status: -1)
23.01.17 09:36:31.188 MAIN ( WARN ) : Cleaning up requests
23.01.17 09:36:31.188 MAIN ( WARN ) : Remove inactivity timer
23.01.17 09:36:31.188 MAIN ( PROCESS ) : ModuleProcess: child died
23.01.17 09:36:32.402 MAIN ( WARN ) : Socket died (module=appcenter)
23.01.17 09:36:32.402 MAIN ( WARN ) : Module process appcenter died (pid: 12739, exit status: -1, signal: -1, status: -1)
23.01.17 09:36:32.402 MAIN ( WARN ) : Cleaning up requests
23.01.17 09:36:32.402 MAIN ( WARN ) : Remove inactivity timer
23.01.17 09:36:32.402 MAIN ( PROCESS ) : ModuleProcess: child died
23.01.17 09:37:26.267 MAIN ( WARN ) : Client: _recv: error on socket: [Errno 104] Die Verbindung wurde vom Kommunikationspartner zur?ckgesetzt
23.01.17 09:37:26.267 MAIN ( WARN ) : Socket died (module=udm)
23.01.17 09:37:26.267 MAIN ( WARN ) : Module process udm died (pid: 12740, exit status: -1, signal: -1, status: -1)
23.01.17 09:37:26.267 MAIN ( WARN ) : Cleaning up requests
23.01.17 09:37:26.267 MAIN ( WARN ) : Invalidating all pending requests 148516064621262-28
23.01.17 09:37:26.267 MAIN ( PROCESS ) : ModuleProcess: child died
23.01.17 09:44:32.573 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘udm’, ‘-s’, ‘/var/run/univention-management-console/3884-1485161072573.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
23.01.17 09:44:32.822 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘join’, ‘-s’, ‘/var/run/univention-management-console/3884-1485161072822.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
23.01.17 09:44:33.063 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘appcenter’, ‘-s’, ‘/var/run/univention-management-console/3884-1485161073063.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
23.01.17 09:44:33.102 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘updater’, ‘-s’, ‘/var/run/univention-management-console/3884-1485161073102.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
23.01.17 09:54:48.787 MAIN ( WARN ) : Socket died (module=join)
23.01.17 09:54:48.787 MAIN ( WARN ) : Module process join died (pid: 15542, exit status: -1, signal: -1, status: -1)
23.01.17 09:54:48.787 MAIN ( WARN ) : Cleaning up requests
23.01.17 09:54:48.787 MAIN ( WARN ) : Remove inactivity timer
23.01.17 09:54:48.787 MAIN ( PROCESS ) : ModuleProcess: child died
23.01.17 09:54:49.060 MAIN ( WARN ) : Socket died (module=updater)
23.01.17 09:54:49.060 MAIN ( WARN ) : Module process updater died (pid: 15546, exit status: -1, signal: -1, status: -1)
23.01.17 09:54:49.060 MAIN ( WARN ) : Cleaning up requests
23.01.17 09:54:49.060 MAIN ( WARN ) : Remove inactivity timer
23.01.17 09:54:49.159 MAIN ( WARN ) : Socket died (module=appcenter)
23.01.17 09:54:49.159 MAIN ( WARN ) : Module process appcenter died (pid: 15545, exit status: -1, signal: -1, status: -1)
23.01.17 09:54:49.159 MAIN ( WARN ) : Cleaning up requests
23.01.17 09:54:49.159 MAIN ( WARN ) : Remove inactivity timer
23.01.17 09:54:49.159 MAIN ( PROCESS ) : ModuleProcess: child died
23.01.17 09:54:50.509 MAIN ( WARN ) : Socket died (module=udm)
23.01.17 09:54:50.509 MAIN ( WARN ) : Module process udm died (pid: 15538, exit status: -1, signal: -1, status: -1)
23.01.17 09:54:50.509 MAIN ( WARN ) : Cleaning up requests
23.01.17 09:54:50.509 MAIN ( WARN ) : Remove inactivity timer
23.01.17 09:54:50.609 MAIN ( PROCESS ) : ModuleProcess: child died
23.01.17 10:44:55.000 SSL ( WARN ) : SSL error in _receive: (-1, ‘Unexpected EOF’). Probably the socket was closed by the client.
23.01.17 10:44:55.000 MAIN ( PROCESS ) : Processor: dying
24.01.17 14:51:18.574 AUTH ( ERROR ) : Canonicalization of username failed: Traceback (most recent call last):
elif res == 2:
24.01.17 14:51:18.986 ACL ( PROCESS ) : Allowed UMC operations:
24.01.17 14:51:18.986 ACL ( PROCESS ) : User | Host | Flavor | Command | Options
24.01.17 14:51:18.986 ACL ( PROCESS ) : ******************************************************************************
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | appcenter/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | apps/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | diagnostic/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | ip/change | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | join/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | lib/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/reboot | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/shutdown | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | lib/sso/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | mrtg/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | packages/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | passwordchange/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | pkgdb/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | quota/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | reboot/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | services/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | setup/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | sysinfo/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | top/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | ucr/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | udm/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | udm/request_new_license | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | updater/* | {}
24.01.17 14:51:18.986 ACL ( PROCESS ) : False | ucsmaster | * | uvmm/* | {}
24.01.17 14:51:20.616 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘join’, ‘-s’, ‘/var/run/univention-management-console/3884-1485265880615.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
24.01.17 14:51:20.674 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘updater’, ‘-s’, ‘/var/run/univention-management-console/3884-1485265880674.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
24.01.17 14:51:20.734 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘udm’, ‘-s’, ‘/var/run/univention-management-console/3884-1485265880733.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
24.01.17 14:51:20.770 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘appcenter’, ‘-s’, ‘/var/run/univention-management-console/3884-1485265880770.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
24.01.17 15:01:23.447 MAIN ( WARN ) : Socket died (module=join)
24.01.17 15:01:23.447 MAIN ( WARN ) : Module process join died (pid: 27264, exit status: -1, signal: -1, status: -1)
24.01.17 15:01:23.447 MAIN ( WARN ) : Cleaning up requests
24.01.17 15:01:23.447 MAIN ( WARN ) : Remove inactivity timer
24.01.17 15:01:23.447 MAIN ( PROCESS ) : ModuleProcess: child died
24.01.17 15:01:23.471 MAIN ( WARN ) : Socket died (module=updater)
24.01.17 15:01:23.471 MAIN ( WARN ) : Module process updater died (pid: 27265, exit status: -1, signal: -1, status: -1)
24.01.17 15:01:23.471 MAIN ( WARN ) : Cleaning up requests
24.01.17 15:01:23.471 MAIN ( WARN ) : Remove inactivity timer
24.01.17 15:01:23.571 MAIN ( PROCESS ) : ModuleProcess: child died
24.01.17 15:01:25.022 MAIN ( WARN ) : Socket died (module=appcenter)
24.01.17 15:01:25.022 MAIN ( WARN ) : Module process appcenter died (pid: 27267, exit status: -1, signal: -1, status: -1)
24.01.17 15:01:25.022 MAIN ( WARN ) : Cleaning up requests
24.01.17 15:01:25.022 MAIN ( WARN ) : Remove inactivity timer
24.01.17 15:01:25.122 MAIN ( PROCESS ) : ModuleProcess: child died
24.01.17 15:08:56.929 MAIN ( WARN ) : Socket died (module=udm)
24.01.17 15:08:56.929 MAIN ( WARN ) : Module process udm died (pid: 27266, exit status: -1, signal: -1, status: -1)
24.01.17 15:08:56.929 MAIN ( WARN ) : Cleaning up requests
24.01.17 15:08:56.929 MAIN ( WARN ) : Remove inactivity timer
24.01.17 15:08:56.929 MAIN ( PROCESS ) : ModuleProcess: child died
24.01.17 15:59:02.343 SSL ( WARN ) : SSL error in _receive: (-1, ‘Unexpected EOF’). Probably the socket was closed by the client.
24.01.17 15:59:02.343 MAIN ( PROCESS ) : Processor: dying
25.01.17 16:39:25.490 AUTH ( ERROR ) : Canonicalization of username failed: Traceback (most recent call last):
elif res == 2:
25.01.17 16:39:26.098 ACL ( PROCESS ) : Allowed UMC operations:
25.01.17 16:39:26.098 ACL ( PROCESS ) : User | Host | Flavor | Command | Options
25.01.17 16:39:26.098 ACL ( PROCESS ) : ******************************************************************************
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | appcenter/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | apps/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | diagnostic/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | ip/change | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | join/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | lib/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/reboot | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | lib/server/shutdown | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | lib/sso/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | mrtg/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | packages/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | passwordchange/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | pkgdb/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | quota/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | reboot/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | services/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | setup/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | sysinfo/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | top/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | ucr/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | udm/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | udm/request_new_license | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | updater/* | {}
25.01.17 16:39:26.098 ACL ( PROCESS ) : False | ucsmaster | * | uvmm/* | {}
25.01.17 16:39:28.365 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘join’, ‘-s’, ‘/var/run/univention-management-console/3884-1485358768365.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
25.01.17 16:39:28.402 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘updater’, ‘-s’, ‘/var/run/univention-management-console/3884-1485358768402.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
25.01.17 16:39:28.418 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘appcenter’, ‘-s’, ‘/var/run/univention-management-console/3884-1485358768418.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
25.01.17 16:39:28.438 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘udm’, ‘-s’, ‘/var/run/univention-management-console/3884-1485358768437.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
25.01.17 16:49:32.103 MAIN ( WARN ) : Socket died (module=updater)
25.01.17 16:49:32.103 MAIN ( WARN ) : Module process updater died (pid: 4087, exit status: -1, signal: -1, status: -1)
25.01.17 16:49:32.103 MAIN ( WARN ) : Cleaning up requests
25.01.17 16:49:32.103 MAIN ( WARN ) : Remove inactivity timer
25.01.17 16:49:32.203 MAIN ( PROCESS ) : ModuleProcess: child died
25.01.17 16:49:32.767 MAIN ( WARN ) : Socket died (module=join)
25.01.17 16:49:32.767 MAIN ( WARN ) : Module process join died (pid: 4086, exit status: -1, signal: -1, status: -1)
25.01.17 16:49:32.767 MAIN ( WARN ) : Cleaning up requests
25.01.17 16:49:32.801 MAIN ( PROCESS ) : ModuleProcess: child died
25.01.17 16:49:35.491 MAIN ( WARN ) : Socket died (module=appcenter)
25.01.17 16:49:35.491 MAIN ( WARN ) : Module process appcenter died (pid: 4088, exit status: -1, signal: -1, status: -1)
25.01.17 16:49:35.491 MAIN ( WARN ) : Cleaning up requests
25.01.17 16:49:35.491 MAIN ( WARN ) : Remove inactivity timer
25.01.17 16:49:35.591 MAIN ( PROCESS ) : ModuleProcess: child died
25.01.17 16:51:06.361 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘appcenter’, ‘-s’, ‘/var/run/univention-management-console/3884-1485359466361.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
25.01.17 16:57:37.423 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘join’, ‘-s’, ‘/var/run/univention-management-console/3884-1485359857423.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
25.01.17 16:57:37.469 MAIN ( PROCESS ) : running: [’/usr/sbin/univention-management-console-module’, ‘-m’, ‘updater’, ‘-s’, ‘/var/run/univention-management-console/3884-1485359857469.socket’, ‘-d’, ‘2’, ‘-l’, ‘de_DE.UTF-8’]
25.01.17 17:07:37.540 MAIN ( WARN ) : Socket died (module=udm)
25.01.17 17:07:37.553 MAIN ( WARN ) : Module process udm died (pid: 4089, exit status: -1, signal: -1, status: -1)
25.01.17 17:07:37.553 MAIN ( WARN ) : Cleaning up requests
25.01.17 17:07:37.553 MAIN ( WARN ) : Remove inactivity timer
25.01.17 17:07:37.553 MAIN ( PROCESS ) : ModuleProcess: child died
25.01.17 17:07:39.560 MAIN ( WARN ) : Client: _recv: error on socket: [Errno 104] Die Verbindung wurde vom Kommunikationspartner zur?ckgesetzt
25.01.17 17:07:39.560 MAIN ( WARN ) : Socket died (module=join)
25.01.17 17:07:39.560 MAIN ( WARN ) : Module process join died (pid: 6605, exit status: -1, signal: -1, status: -1)
25.01.17 17:07:39.560 MAIN ( WARN ) : Cleaning up requests
25.01.17 17:07:39.560 MAIN ( WARN ) : Invalidating all pending requests 148536045954958-45
25.01.17 17:07:39.660 MAIN ( PROCESS ) : ModuleProcess: child died
25.01.17 17:07:47.896 MAIN ( WARN ) : Socket died (module=updater)
25.01.17 17:07:47.896 MAIN ( WARN ) : Module process updater died (pid: 6606, exit status: -1, signal: -1, status: -1)
25.01.17 17:07:47.896 MAIN ( WARN ) : Cleaning up requests
25.01.17 17:07:47.896 MAIN ( PROCESS ) : ModuleProcess: child died
25.01.17 17:07:47.915 MAIN ( WARN ) : Socket died (module=appcenter)
25.01.17 17:07:47.915 MAIN ( WARN ) : Module process appcenter died (pid: 5802, exit status: -1, signal: -1, status: -1)
25.01.17 17:07:47.915 MAIN ( WARN ) : Cleaning up requests
25.01.17 17:07:48.016 MAIN ( PROCESS ) : ModuleProcess: child died
root@ucsmaster:/var/log/univention# cat management-console-web-server.log
23.01.17 09:26:26.521 MAIN ( PROCESS ) : SessionClient(0x2c68b90): _authenticated: success=True status=200 message=None
24.01.17 14:51:18.756 MAIN ( PROCESS ) : SessionClient(0x2d3e790): _authenticated: success=True status=200 message=None
25.01.17 16:39:25.853 MAIN ( PROCESS ) : SessionClient(0x2d53cd0): _authenticated: success=True status=200 message=None
[/code]
