Hello together,
after upgrading to 5.0-2 I get a lot of emails - generated every 5 minutes - like:
Cron <root@ucs-01> run-parts /usr/share/univention-monitoring-client/scripts/:
File "/usr/share/univention-monitoring-client/scripts//check_univention_dns", line 46, in <module>
DNS.main()
File "/usr/lib/python3/dist-packages/univention/monitoring/__init__.py", line 73, in main
with open(os.path.join(NODE_EXPORTER_DIR, '%s.prom' % (plugin,)), 'w') as self._fd:
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_dns.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_dns exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_i2o_raid", line 96, in <module>
I2O_RAIDCheck.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_i2o_raid.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_i2o_raid exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_joinstatus", line 170, in <module>
JoinStatusCheck.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_joinstatus.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_joinstatus exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_kpasswdd", line 44, in <module>
Kpasswdd.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_kpasswdd.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_kpasswdd exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_ldap", line 54, in <module>
LDAP.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_ldap.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_ldap exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_mdb_maxsize", line 75, in <module>
MDBMaxsize.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_mdb_maxsize.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_mdb_maxsize exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_nfsstatus", line 93, in <module>
FSMountCheck.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_nfsstatus.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_nfsstatus exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_nmbd", line 74, in <module>
NMBD.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_nmbd.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_nmbd exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_nscd", line 64, in <module>
NSCD.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_nscd.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_nscd exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_ntp", line 46, in <module>
NTP.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_ntp.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_ntp exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_package_status", line 47, in <module>
PackageStatus.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_package_status.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_package_status exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_ping", line 45, in <module>
Ping.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_ping.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_ping exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_printerqueue", line 62, in <module>
Printerqueue.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_printerqueue.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_printerqueue exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_replication", line 68, in <module>
ReplicationCheck.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_replication.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_replication exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_s4_connector", line 75, in <module>
S4Connector.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_s4_connector.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_s4_connector exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_samba_drs_failures", line 86, in <module>
CheckSambaDrsRepl.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_samba_drs_failures.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_samba_drs_failures exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_smbd", line 61, in <module>
SMBD.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_smbd.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_smbd exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_smtp", line 49, in <module>
SMTP.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_smtp.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_smtp exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_ssl_certificate", line 62, in <module>
SSLCertificateCheck.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_ssl_certificate.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_ssl_certificate exited with return code 1
File "/usr/share/univention-monitoring-client/scripts//check_univention_winbind", line 51, in <module>
Winbind.main()
FileNotFoundError: [Errno 2] No such file or directory: '/var/lib/prometheus/node-exporter/check_univention_winbind.prom'
run-parts: /usr/share/univention-monitoring-client/scripts//check_univention_winbind exited with return code 1
First impuls was to install the dashboard-app and see if that changes the messages.
But Iâm not sure about the licence. The appcenter tells:
âKostenlose kommerzielle Nutzungâ and if I click the link below it tells I need a subscriptionâŠ
is it âkostenlos bei kommerzieller Nutzungâ?
Any other approach would also be appreciated.
Best,
Bernd
