Has anyone successfull installation of Media Wiki ?
I tried to test this App - but could not login after installation - is there some sprecial setting to do after the installation beside enabling the user in the UCS User Modul ?
rg
Christian
rg
Christian
Hello @externa1,
I assume you talk about BlueSpice Mediawiki. The app provider is working on an update. I don’t know whether they know about a login problem.
Best regards,
Nico
yes BlueSpice,
ok I’ll wait for an update - maybe this probleme is gone with it
rg
Christian
Hello externa1,
thank you for your notice. There is a known issue with IP numbers. We are working with Univention on it and the next update will hopefully fix it.
But maybe your case is different. Have you seen the article in our helpdesk? https://en.help.bluespice.com/wiki/Univention
Best regards!
Richard
Hello @externa1,
how does you UCS host obtain his IP address? Is it dynamically via DHCP or statically with a manual IP address configuration? If it is with DHCP, does UCS always receive the same IP address or does it change?
Best regards,
Nico
It’s on an UCS Backup, and its static
lg
christian
Thanks. Well, this does not match with the description of an issue I had in mind that could be the cause.
Update to Version 2.27.2-ucs.2 solved the login problem for me
rg
Christian
Perfect. Thank you for your feedback!
