Manage several domains with UCS - solved
Hey,
i have several domains, that shall be managed (in relation to E-Mail) with Kopano and UCS. I also want to receive the server (over all domains) from the internet, over ssh & co. How can i realize that with UCS?
Thanks for your help
[GER]
habe mehrere Domainen, die ich gerne E-Mail-technisch mit Kopano und UCS verwalten würde. Außerdem sollte man den UCS Server von allen Domainen aus (aus dem Internet, per ssh etc.) erreichen. Wie kann ich das mit UCS umsetzen?
Vielen Dank für Eure Hilfe
Niki
Hi Niki,
you can add multiple mail domains in UMC -> Domain -> Mail.
Each of these domain is then valid as primary or alternative mail address domain of user accounts.
Do your user accounts overlap the domains? E.g. has a single user email addresses from 2 of these domains?
In that case only one email address can be the primary email address.
To reach a single server through different domains from the internet via SSH you need to setup DNS with your domain registrar accordingly. That means that each domain points to the same IP address.
But still the SSH server will only report the domain name it was installed with as it’s domain name.
If you would like to get HTTPS working with multiple domains you need to create the SSL certificate that the web server uses to include all these domains.
BR,
Jörn
ok thanks, yeah they overlap, so i´m gonna choose a primary email adress.
have a nice day
Niki
