Was ist die Ausgabe von
cat /etc/apt/sources.list.d/20_ucs-online-component.list
und
aptitude -s dist-upgrade
und
~# cat /etc/apt/sources.list.d/20_ucs-online-component.list
#Warning: This file is auto-generated and might be overwritten by
# univention-config-registry.
# Please edit the following file(s) instead:
#Warnung: Diese Datei wurde automatisch generiert und kann durch
# univention-config-registry überschrieben werden.
# Bitte bearbeiten Sie an Stelle dessen die folgende(n) Datei(en):
# /etc/univention/templates/files/etc/apt/sources.list.d/20_ucs-online-component.list
deb http://appcenter.software-univention.de/univention-repository/3.2/maintained/component/ xrdp/all/
deb http://appcenter.software-univention.de/univention-repository/3.2/maintained/component/ xrdp/amd64/
deb http://appcenter.software-univention.de/univention-repository/3.1/maintained/component/ xrdp/all/
deb http://appcenter.software-univention.de/univention-repository/3.1/maintained/component/ xrdp/amd64/
deb http://apt.univention.de/3.2/maintained/component/ 3.2-3-errata/all/
deb http://apt.univention.de/3.2/maintained/component/ 3.2-3-errata/amd64/
deb http://apt.univention.de/3.2/unmaintained/component/ 3.2-3-errata/all/
deb http://apt.univention.de/3.2/unmaintained/component/ 3.2-3-errata/amd64/
# Configuration error: component not found: sec2.3-4-samba3.3.10
deb http://x:x@software.open-xchange.com/OX6/OXSEforUCS/2.4/maintained/component/ox/ ./
deb http://x:x@software.open-xchange.com/OX6/OXSEforUCS/2.3/maintained/component/ox/ ./
deb http://x:x@software.open-xchange.com/OX6/OXSEforUCS/2.2/maintained/component/ox/ ./
Da sind wohl noch alte EInträge drin
~# aptitude -s dist-upgrade
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Would download/install/remove packages.
Ich habe nun die
repository/online/component/oxseforucs_20140708
Einträge vom DC Backup auf den Master übernommen. Nun hat univention-upgrade auch das Paket python-univention-ox-common updated.
Fehler behoben! Suche funktioniert nun.
Danke!!
