Load Balancing - Amazon - Stress Tests
Hi all,
I have my UCS instances in Amazon AWS Ec2. I have one Master and 2 backups. I did some stress tests and Load on Master was 15-20 :frowning: I know I can change my instance for Master but I wish to ask you about:
  • did you do any stress tests before go to production state?
  • do you use Amazon EC2 for UCS instances?
  • is it possible to run Elastic Load Balancer on UCS? I mean if load is bigger then 5, then start another instance. In this case I’m afraid about data discrepancy.
Thank you so much for answer.
Best,
Rafal
