Hello Everyone,
I have a big problem with the letsencrypt certificate.
I installed the letsencrypt app from the app center, and it actually worked very fine and my website was totally secured and I could install the E-Mail on iPhone with no problems.
Now I got a certificate failure in the iPhone and get the non-secure website failure again.
when I try to reinstall the account on the iPhone I get a failure says the certificate are expired on the 30.11.
I executed the corn job manually to renew the certificate and I got the following error
Mi 8. Dez 15:17:20 CET 2021
Refreshing certificate for following domains:
owa.dattel.de
Parsing account key…
Parsing CSR…
Found domains: owa.dattel.de
Getting directory…
Directory found!
Registering account…
Already registered!
Creating new order…
Order created!
Verifying owa.dattel.de…
File “/usr/share/univention-letsencrypt/acme_tiny.py”, line 197, in
main(sys.argv[1:])
File “/usr/share/univention-letsencrypt/acme_tiny.py”, line 193, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File “/usr/share/univention-letsencrypt/acme_tiny.py”, line 149, in get_crt
raise ValueError(“Challenge did not pass for {0}: {1}”.format(domain, authorization))
ValueError: Challenge did not pass for owa.dattel.de: {u’status’: u’invalid’, u’challenges’: [{u’status’: u’invalid’, u’validationRecord’: [{u’url’: u’http://owa.dattel.de/.well-known/acme-challenge/iACHuUtDYJFDBJk12KgDB1ShCKaSlSq6s6oYVMTOFLI’, u’hostname’: u’owa.dattel.de’, u’addressUsed’: u’81.27.115.44’, u’port’: u’80’, u’addressesResolved’: [u’81.27.115.44’]}], u’url’: u’https://acme-v02.api.letsencrypt.org/acme/chall-v3/56609409560/EOfKyA’, u’token’: u’iACHuUtDYJFDBJk12KgDB1ShCKaSlSq6s6oYVMTOFLI’, u’error’: {u’status’: 400, u’type’: u’urn:ietf:params:acme:error:connection’, u’detail’: u’Fetching http://owa.dattel.de/.well-known/acme-challenge/iACHuUtDYJFDBJk12KgDB1ShCKaSlSq6s6oYVMTOFLI: Timeout during connect (likely firewall problem)’}, u’validated’: u’2021-12-08T14:17:26Z’, u’type’: u’http-01’}], u’identifier’: {u’type’: u’dns’, u’value’: u’owa.dattel.de’}, u’expires’: u’2021-12-15T14:17:24Z’}
Setting letsencrypt/status
Module: kopano-cfg
run-parts: executing /etc/univention/letsencrypt/post-refresh.d//apache2
run-parts: executing /etc/univention/letsencrypt/post-refresh.d//dovecot
run-parts: executing /etc/univention/letsencrypt/post-refresh.d//postfix
Can anybody help?
uninstalling the app doesn’t really work
Regards
Michael
